Taking a stock 97 IRS higher than 3 inches
mark21742
Right now i have a 3 inch lift in the front (aftermarket struts with stock springs and 1 inch diff drop), 4-7 inch adjustable lift in rear (stock springs, raised lower spring mount, 1 inch spring spacer on top and in coil airbags). Running 305/70 16s (33s) on stock wheels with 2 inch spacers.
I can cut/ weld to do any fab work if needed, but was wondering how many if any have gone higher than 3 inch lift in the front, how much this cuts down the life of CV joints/axles, or if the diff needs to be dropped further.
Before spring comes id like to lift her a few more inches adding longer travel/ better springs/ struts, but would like to keep the IRS if possible because we use my 4runner all the time for trips, hauling kids, bicycles, motorcycles, and trailer but also enjoy some off roading from time to time.
Basically looking to make her the best all around vehicle i can while also keeping it reliable and safe for work and street use.
Lots of parts are going to wear out faster with that much lift. It's going to feel like driving a bowling pin. Not what I would consider safe for street use. I think it's been done I think you need a bracket lift to achieve it. I forgot who makes it, but I think it was either Fabtech or Trailmaster.
seltzernator
