Temperature Gauge Sender Type
sdb999
Member
There are two kinds of senders. One is just for the dummy light, and other are for gauge clusters with the temp gauge.
Thats all I know about them.
I ended up going with a mechanical temp gauge, works great in the factory location behind the thermostat. I was able to easily feed the sender lead into the cab of the truck via the hvac drain tube. This large grommet is on the firewall on the passenger side. Both the drain tube and grommet are soft rubber so the sender lead slipped in right next to the drain tube. No holes drilled, No rubber cut, and very tight seal.
Talyn
