The 4th gen TRD PRO wheel picture thread
265/70/17
Planning on running stock springs with bilstein 5100's set to .85" in the front with 265/70/17, will I rub at all with this setup?
My 5100's are set at the next level up. I have the 265/70/17 Nitto Ridge Grapplers. I had a tiny bit of rubbing in reverse at full lock up. The tires were hitting the little "pods" that protrude down from the fender liner. I just loosened the bolts, shoved the "pods" as far forward as they would go, and then tightened the bolts back down. Voila! No rubbing!
That said, I have not gone off road yet, so there may be rubbing at full compression. However, my research says we should be fine.
More pics of your runner please. I have a silver one just like yours and will be going with these wheels more than likely and have 265/70 Nitto Terra Grappler G2's, so pretty similar.
Just got my TRD Pro's today, they are sweet. Now to save up for some tread. My question is, can I swap over the TPMS valves from my '06 Sport ?
I'm tackling this now. Depends on what year you're moving from and to. I am buying replacement tpms sensors for my 06, but it looks like there was a change in tpms types in mid 2006. Trucks built 7/2006 forward use a different tpms than trucks built pre-7/2006.
Mine was manufactured 11/2005 based on the door Information placard so it takes the older sensors.
Sent from my SM-G935V using Tapatalk
I was reading the info that came with the Pro wheels, says tpms needs to be 20 degree kind. I'm hoping the ones in my original sport rims will work. Mine was manufactured 11/05 also.
Haven't had a chance to take any quality pictures yet, but here are a couple from my parking lot at work this morning.
SO, Scott maybe you could answer my question about using the original TPMS sensors since you have a 2006 Sport also. What did you do?
Not sure if this will apply to your 2006, but I had a some dead batteries in the original TPMS sensors and opted to replace them when putting the new wheels on my 2008. I went with these:
https://www.amazon.com/gp/product/B00NQ05U24/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
They had to be paired by manually entering each serial number, but they worked out just fine aside from that.
One of my tpms sensors was corroded in the factory wheel so I didn't transfer any of them over when the TRD rims were mounted. Plus they were all 12 years old and due for failure, anyway. It actually took about 200 miles of driving before the tire light started to flash.
Ordered new Densos, they were delivered this weekend. Going to have them installed in the next couple of weeks. Mine is an 06, manufactured 11/2005 so I ordered the pre-7/2006 sensors.
I really don't know. Didn't know there was a difference in 4th Gen tpms sensors at all until I started shopping to buy new ones.
Getting mine installed tomorrow. Just having them in the truck and I can already see the truck detects them and is receiving temperature readings.
These are Denso 550-0101 sensors going on a 2006 manufactured 11/2005
