The Flat Earth Society
ROFL "The sun and moon, each 32 miles in diameter, circle Earth at a height of 3000 miles at its equator. They are located midway between the North Pole and the ice wall. Each functions similar to a "spotlight," with the sun radiating "hot light" and the moon "cold light." As they are spotlights, they only give light out over a certain places, which explains why some parts of the Earth are dark while others are clear. Their apparent rising and setting are caused by optical illusions.
Im reading some of the threads,LMAO, my God, they are lost, they REALLY believe the earth is flat.
heres some of my favs.
Q: "Why doesn't water run off the Earth?"
A: There is a vast ice wall that keeps the water where it is. The ice wall is roughly 150ft high. This also explains why you can find a vast plane of ice when you travel south. Antarctica as a continent does not exist.
Q: "If you go directly south won't you eventually fall off the edge of the Earth?"
A: Yes, you will. In order to use this fact as proof you need to record a video of someone flying directly south around the world without falling off the edge. Furthermore you need to prove that your navigational equipment allows you to travel directly south without deviating.
:lmao:
I know man, its mind boggling to think that people today can believe an idea that was disproved by the ancient greek astronomers over 2 thousand years ago
You guys had better lay off them. They are serious. You might get a notice from their lawyers Geldsnatch, Geldsnatch and Blubberclutch.:)
LMAO, i seen a few posta, where they said something to the effect, if you try to dicredit them, the comspiricy people will kill you, lol
wwarren702
