throttle body problems ..NO POWER
andy3882
Long story short I talked my girlfriend into buying a 2010 4runner with 38K miles on it, she previously had a 2008 jeep grand Cherokee with 90k miles on it and I was scared of the transmission going out and a 3k repair(common problem). Plus the only car in my opinion to drive is a Toyota, that's all I have ever driven. We bought the 4runner from a local non Toyota dealer and put 1200 miles on it when...
The check engine light comes on and the car has absolutely no power and wont move just idles, ....I got the car to advance where they pull the code 2111 throttle actuator stuck open. Now find out there is a bulletin for it TSB 0092-11. But the car has 39k miles on it now. I just looked at the local car dealer warranty 30days/1000miles oh boy nice...I thinking girlfriend going to be pissed at me :yell: So my question is ???????
1. Does anyone have a copy of this tsb? I saw a one page of it on this forum but it didn't state the mileage or the time frame of the tsb.
2. How many miles does it cover to? Am I covered still 39k miles?
3. I cleared the code but does the ecm keep a record of the code and at what mileage it set the code off. REALLY WANT TO KNOW THIS!!!!!
4. Any advice would be appreciated. This forum has been a wealth of knowledge and want to thank all for the info shared here.
Thanks Andy
Thanks Andy
Hi Andy,
Not sure if you've seen these posts here on forum; seems you're not the only one who's encountered this issue.
https://www.google.com/url?q=http:/...ds-cse&usg=AFQjCNG1iIBAxEy0X6IGJ2xoKHSOBdW6UQ
"This is pg 3, please see pg #1 first"; Hope this relates to your trouble, good luck!
rigtec, Cheers
powertain is anything that affects proper operation of the engine/transmission etc.
Not sure if it was actually posted but I'll be happy to grab the tsb for you tomorrow.
I called corporate Toyota today and stated my problem and tsb 0092-11 .......They sated this tsb is only covered 3yrs/36000 miles ......
.:doh:
Well this sucks, anyone know what the part actually costs?
Throttle Body
I think someone at corporate did not tell you the full story. According to the power train warranty anything that will not power the vehicle as it was designed is covered by the 5 year/60,000 warranty. This would even include the wheel hubs, as on one of my previous Toyota's the RR hub was warped and caused the car to have a weird feel and sound at certain speeds. The vehicle at the time had over 40,000 miles on it and it was past the 36 month bumper to bumper warranty. Check with a Toyota dealer.
typical Toyota ....you have got to love their vehicles but their service is questionable. It s like they do everything to try and get out of warranty work.
I really need a copy of the full TSB 0092-11
On the contrary: That's your dealer, not Toyota. If you have a CS-oriented dealer (as I do) it couldn't be better.
Which are scarce to non-existent. Here in NoVA the dealers like to charge MSRP + 25% for accessories and parts, because you suck and they hate you.
I LOVE TOYOTA TRUCKS AND SUVS
I however do not like the local dealerships or corporate Toyota.
No conflict in my eyes because thankfully I rarely have to see the dealership or the corporate reps thanks to Toyotas reliability.
I would just like to have a copy of the full TSB 0092-11 so I may look at it myself. And see if they changed the part number.
Ps. I found a new oem throttle body for $650.00 but I will wait to see if this may be covered under warranty and if the code comes back .
Thanks guys
Thanks guys
You are making no sense.
Everyone here, and I would listen to them because people like [MENTION=55815]Okki[/MENTION] and others know what they are talking about, are telling you it IS under warranty. Now, if you hate your dealer so much you would rather spend $1000.00 avoiding them then tell us that. These guys are telling you what to do to get it fixed under warranty.
Go to the dealer and get a copy of the TSB.
Tell the dealer to test it and if it exhibits the same issues as the TSB covers you will get it fixed no charge because of the 60K mileage.
You mention resetting your codes. Who is working on the truck now?
Lastly, what dealer in WV is so terrible?
It is covered..........,5year/60 k powertrain warranty -print this off and take it to the dealer-The ECU stores the codes so it will still be there until it is cleared with Techstream.
This is actually a safety issue as it could happen at any time again,like pulling out into traffic. I would get it replaced ASAP http://www.factorywarrantylist.com/uploads/3/3/9/4/3394652/toyota_warranty_policy_flyer.pdf
Edit: Here's another dealer warranty manual from Toyota I found. I'm not sure the dealers want this one out there. Where are attorneys on the forum??? lol
http://www.uotdealereducation.com/REPOSITORY/COURSE/DOCS/{E9B2F1D1-3A93-4063-BB42-1CF9D72275C2}.PDF
I recant my earlier statement as now I'm not sure if it will be covered.Wow ,after actually reading the long azz dealer manual , policy 4.4 for powertrain and some research as most manufacturers don't cover the Throttle Body anymore with many complaints. The TB from what I see is not covered for the Toyota powertrain warranty which is total BS. The TB is part of the engine/drivetrain IMO and a vital one at that IMO. Can't hurt to try but when they pull up the part number it will tell them what the warranty is and I hope the TSB states a longer warranty.
Powertrain Component List ....Everthing but TB!!
Engine
• Automatic timer
• Camshaft
– Distributor drive gear
• Camshaft housing
• Camshaft housing gasket
• Camshaft timing gear or sprocket
• Chain tensioner assembly
• Compression spring and/or retainer and/or oil seal and/or retainer lock
• Connecting rod assembly and/or solid bushing
• Connecting rod bearing
• Crankcase subassembly
• Crankshaft and/or crankshaft bearing
• Crankshaft front oil seal
• Crankshaft gear or sprocket
• Crankshaft pulley
• Crankshaft rear oil seal and/or retainer (ATM)
• Crankshaft rear oil seal and/or retainer (MTM)
• Cylinder block
• Cylinder head cover assembly
• Cylinder head cover gasket
• Cylinder head gasket
• Cylinder head subassembly
• Cylinder liner and/or shim
• Drive plate subassembly (ATM)
• Electric fuel pump assembly
• Electronic control computer
• Engine front mounting bracket and/or insulator
• Engine oil pump assembly (OH)
• Flywheel subassembly and/or hexagon bolt
• Fuel feed pump
• Fuel pump assembly and/or gasket
• Injection pump assembly
– Delivery valve and/or gasket
– Injection pump camshaft
– Injection pump camshaft bearing
– Pneumatic governor diaphragm
– Other internal parts
• Oil filter bracket subassembly
• Oil pan gasket
• Oil pan subassembly
• Piston ring set
• Piston subassembly with pin
• Pump drive shaft
• Short block
• Supercharger
• Timing belt
• Timing belt idler
• Timing chain
• Timing gear case assembly
• Timing gear cover assembly
• Transmission input shaft bearing (pilot bearing)
• Turbocharger assembly
• Valve lash adjuster
• Valve lifter
• Valve pushrod
• Valve rocker shaft and/or arm and/or support
• Valves and/or bushing
• Valve adjusting screw
• Valve rocker arm bushing
• Water outlet and/or gasket
• Water pump assembly and/or gasket
• Water pump rotor kit and/or seal set
• Water pump bearing
Manual and Automatic Transmission/Transaxle
• Automatic transmission assembly
– Governor assembly
– O-ring (for front oil pump)
– Oil seal (for front oil pump)
– Oil seal (for manual valve lever shaft)
– Torque converter assembly
• Manual transmission assembly
– Countershaft bearing and/or countershaft
– Countershaft gear
– Engine mounting rear insulator and/or support
– Extension housing gasket
– Extension housing subassembly
– Input shaft
– Output shaft assembly
– Synchronizer ring
– Transmission case
– Transmission case cover
– Type T oil seal (extension housing)
– Type T oil seal (front bearing retainer)
• Hybrid vehicle system transaxle/motor/generator
– Transaxle mounts
– Seals and gaskets
• Speedometer drive gear subassembly
• Speedometer shaft and sleeve
– O-ring and gasket
• Transfer assembly
– Front drive shaft oil seal
– Output shaft bearing retainer and/or seal
– Transfer case cover no. 2
– Transfer power take-off cover and/or gasket
Propeller Shaft
• Center support bearing
• Drive shaft assembly
• Drive shaft assembly with intermediate shaft with center support bearing
• Drive shaft intermediate assembly
• Equipment drive shaft assembly
• Hexagon bolt
• Universal joint spider
Universal joint yoke subassembly with sleeve
Rear Wheel Drive
• Differential carrier assembly
– Bearing (for drive pinion)
– Differential carrier gasket
– Differential carrier subassembly or rear axle housing
– Differential case subassembly
– Differential pinion and/or differential side gear
– Differential ring gear and drive pinion kit
– Differential side gear shaft subassembly
– Oil seal (for differential carrier)
– Rear axle shaft
– Rear axle shaft bearing
– Tapered roller bearing (for side bearing)
– Type T oil seal
– Universal joint flange
• Independent rear suspension type
– Rear axle shaft
Drive shaft boot
Rear axle flange subassembly
Rear drive shaft assembly
Type T oil seal
• Rigid suspension type
– Differential carrier cover
– Differential carrier cover gasket
– Rear axle housing assembly
Restraint System
• Front seat belts
• Rear seat belts
• Air bags
That's a bummer it might not be covered under warranty!
OP:
If it is NOT covered under warranty.
Just order the new part throttle body. Part number should be listed in the TSB.
Order that part yourself online with a discount and change it yourself.
Should be easy to change. Save yourself $500+ on retail pricing on parts plus labor.
2001ATL
