Tightened negative terminal and it broke
sugjavier
Member
Had starting issues for like 4 months now, and I know for sure we eliminated the alternator and the battery (brand new/tested - 100%)
So I had the Autozone guy tighten up my terminals cuz last time I had an issue, it was just loose/corroded so we cleaned/tightened it.
Anyways it broke, and it wasn't his fault, I was watching and while it was turning a lot w/o much force then the bolt head broke :(
I was reading up on the Big 3 upgrade but I just need the wiring kit as my alternator/battery is still good.
What/where do you guys recommend for the replacement?
Can I just get a negative terminal replacement OR do I have to replace the entire wire including the positive terminal?
I can't find a the actual part number. I'd like to know what you guys are rocking..maybe some stainless steel?
Also I'm assuming this is a pretty cheap fix right?
