tps adjustment.
2ndgenmafia
i replaced my bad vafm with a new one and now i have it started and am getting code 52 & 41. knock sensor and tps. im hoping the tps is just out of adjustment bc of the new afm and the code 52 is coming from the tps out of adjustment and is running lean/rich and has a slight ping. right now it has NO powe. struggling to pull its own weight. any help on adjusting the tps would help.
When you go to the local PNP, take a picture of the TPS connection with you and get the pigtail off a car with the same plug. Get as much wire as you can. I added some alligator clips to the pigtail and found it much easier to set the TPS by clipping the probes on the multimeter to the alligator clips than trying to hold the probes to the TPS and still operate the throttle.
seltzernator
