Transfer case rear driveshaft seal leak
parsky1
Member
I just serviced all the 4wd fluids and switched to Redline 75w-90. 190k. I noticed a hanging drip of fluid at the rear output of the transfer case to the drive shaft. Should I just replace the seal? I’ve heard before that replacing the seal is just a bandaid because usually a worn out bushing causes too much play and that wears out the seal. Thanks.
This is the best video I could find but it’s not a 4th gen…. Anyone know of a better one?
DIY: Toyota 4x4 Transfer Case Rear Flange Oil Seal Replacement - YouTube
Replacing the seal can be a temporary fix if the underlying cause isn't addressed. Make sure you take a good look at the bushing for any signs of wear and play. If it's showing some serious wear, it's probably a good idea to change both the bushing and the seal. That way, you can really sort things out and avoid having the same problems pop up again.
delislerebecca
