transmission cooler
Mulepick said:
<Would you try and thaw a frozen steak with air or water? (and more)>
The Laws of Thermo deal with heat, not fluids. It's all about delta T (the difference in temp).
Water or air? You cool your beer with all the water you want; I'll cool it with air, -50'F at velocity. Bet I'll freeze it first!
Actually Thermodynamics deal with the TRANSFER of energy from one place/state to another. Hence, the transfer of heat (internal energy) from one system to another system.
I'll bet a flowing liquid @ -50F will cool that same beer in a fraction of the time it takes you to cool it with moving -50F air! Betcha... What I'll give you is the fact that you can produce -50F air WAY easier and cheaper than I can produce -50F liquids...
Every throw a party? Ever notice your beer gets colder at a faster rate if you add water to your ice in the cooler? Just ice alone works well over time, but when you add water it works better and faster. Why? Becuase the cans/bottles only touch the ice with a small amount of surface area. The rest of the surface area is being cooled by the surrounding 32F air. When you add water, you get 32/33F (approx) water and ice eveloping the can/bottle. Hence, providing a 100% surface area coverage AND using water to transfer the heat energy from the water to the bottle... Versus using air and ice to do the heat exchange.....
Wonder why they dont cool nuclear reactors with air? Wonder why they use moving water?
A flowing liquid is best for transfering heat energy from one system to another. The movement allows you to draw heat away from one system to another at a faster rate.
Hence, wind-chill factor.... Moving air is also going to draw heat away from your body faster than idle air.
Moving liquid transfers better than a stagnant liquid. Moving Air exchanges at a faster rate than non-moving air. AND a liquid transfers heat energy more efficiently than a gas. Hence, moving liquids transfer heat energy (entropy) at a faster rate and more efficiently than moving air....
It been a while since I took Thermo and Physics... But I am fairly certain moving liquid works best in most situations. I dont know about extreme situations. I dont know if the calculations hold true or change at a certain point betweed a solid, liquid, or gas when you start to approach large numbers. Maybe absolute zero air will entropy at a faster rate than a flowing liquid at the same temp. But what liquid flows at absolute zero? Also, how do you harness or produce absolute zero without the expense to produce it? What ever you have at absolute zero, be it gas, liquid, or solid how did you get such a thing to absolute zero? To get it there it had to transfer energy from another absolute zero system... And so on...
So I think in terms of systems that are in a normal range of temperatures (here on Earth), and given the ease and expense of such systems (absolute zero benig very expensive), we can say that a moving liquid (for our purposes) works best....
I have NO idea what I just typed... Psycho-babble?
:arrow: :arrow:
Sure, I'll beat a dead horse.
Now that last post made sense. You should have started out that way instead of making hard and fast comments about water versus air, constant radiator temps (I live in NV!), and whatever number 3 is. (Things always come in threes).
BTW, yep water is used in reactor cooling. Liquid sodium works even better to transfer heat. Just ask former Soviet submariners. Also ask them what happens when water touches that Na!
Enough engineering, I'm not on the clock.
I can't believe that in all this conceptual talk about heat transfer by liquid vs. by air, nobody has talked about mass or conductivity. All frozen steaks aside, there are many things for Toyota's engineers to consider in designing the 4Runner's cooling system(s) and if we are to get into their heads, we're going to have to dig a lot deeper than liquid vs. air cooling. Fortunately for the forum, I have neither the time nor the interest to do this...
Just to be the devil's advocate, Toyota wants the trans to run at operating temp. So, the objective is to keep the fluid at 190 degrees. This is done by the use of the main rad. Therefore wouldn't you want to run the fluid through the external heat exchanger first and then through the main rad to maintain operating temp?
Koz
2011 Limited, No Transmission cooler?...
Does anyone know if the 5th gen 4runners come with a Transmission cooler? I can't see one on mine, but i may not be looking hard enough. I would also like to know where to order one and if its worth the install. ALSO, Does anyone know if you can install a fan on the front of the radiator like in sequoias to help keep the AC cold when idling. Especially when its 110, and Humid. Thanks!
2006 V-8 Towing
Sorry if repeat
Want to take 5,000lb trailer farther distances, inquiring about oil and or tranny cooler, one or both necessary? Purchased Hensley Hitch to elminate sway, now I need to negate heat.
On Friday January 5th I brought my Toyota 4Runner V8 2005 to the Toyota dealer in West Roxbury MA. The issue was a leak in what I thought was a clamp that connected the power steering line to a hose (see picture) After the mechanics reviewed my car the assessment was that the transmission cooler lines need to be replaced. I want to point out that those lines are under the car, and not in front where I saw the leak. They said that the car would be ready mid-day on Saturday January 6th. On Saturday after receiving a call from the dealer I went to pick up my car at 1:30pm. The total cost for the repair was $473.39 The repair included the replacement of transmission cooler lines, 2 bolts, 4 clips, Automatic Transmission fluid, and labor.
After receiving the car, I immediately opened the hood and realized that fluid was still coming out of the connection shown in the pictures. I decided to go home and take a closer look. At my house I was able to remove the skid plate under the car and I examined the work that was done by the dealer. Everything looked fine except that one of the 4 clips that I was charged for was not new (see pictures). After completing my own assessment at home, I went directly back to the dealer to investigate further why the repair was not done properly. When I arrived, I talked to a different service consultant and explained the situation. I told him that I couldn’t leave the car with the mechanics at that time, but I would like to make sure a note was made in my file that acknowledged the situation. The guy refused to make the note in my file, and said that in order to do that I have to leave the car with them, and because they were closing in an hour no one could see the problem until Monday. I told the guy that I would come back on Monday morning.
On Sunday I had to drive to work, and at this point the leak was getting worse. At the end of the day, when I was returning home, the car was making a really bad noise when I turned the steering wheel, and at that point I realized that the power steering fluid was gone, and the leak on the connection of the power steering lines was still there.
On Monday January 8th I went back to the dealer and explained to them what had happed since I received the car on Saturday, using print outs of pictures. The service consultant told me that they would look at the situation and find a solution. After almost three hours, they said that they realized the mechanics had made a mistake and they would fix the power steering lines and they would also replaced the clamp on one the transmission cooler lines that I had already paid for which was never replaced in the first place. This guy said that they would cover the labor, but I had to pay for the parts. I thought it was a good deal and I approved the work. The total cost was 478.86, this included lines, bolts washer and fluid.
The car was ready for pick up on Tuesday morning, and I drove the car to work, and at the end of the day I returned home. On Wednesday January 11th, I decided to open the hood of the car to check things out, and to my surprise the transmission cooler that is in front of the car was leaking.
Looking at picture from Friday January 5th, you can see that the transmission cooler did not have any leak at that time, and that the leak began after the last work done on Monday January 8th by the dealer.
There are several concerns with the service that I have received from this dealer. First of all, the first diagnosis was wrong, the problem I went in for was not fixed, and I was charged for a repair that was not really needed; furthermore, the mechanics did not replace all the clips for the transmission lines that I was charged for. After coming back for a second time the power steering lines were fixed but a new leak was created in the transmission cooler.
Now I understand why folks call them stealership!!
I ordered new transmission cooler, hoses and clamps and I will do the work myself this time.
Here are the parts that I used to replace the transmission cooler for a 4Runner V8 2005.
1 Trans Cooler (32910-60150)
1 Inlet Hose (32943-60320)
1 Outlet Hose (32942-60410)
4 Inlet Hose Clamp (90466-16004)
2 Condenser Mount Bolt (90119-06336)
1 Air Duct Bolt (90119-06420)
3 Fan Blade Bushing (90099-32130)
3 Fan Blade Retainer (88467-14070)
I bought all the parts from an online Toyota dealer.
I realize this is an older thread, but I am amazed that you just accepted that you were ripped off. Where you charged twice? $900?Or did they refund you for the work they didn't do, and created the transmission repair?
I would have had to been dragged out of there if this had happened to me!
It was standard equipment in the U.S. when I bought my 2004, at least on the V8s, the only options listed on the window sticker of my truck were roof rack and floor/cargo mats.
My T4R has a roof rack and it's a v6 sport edition...but my truck also is completely loaded heated leather seats sun roof navigation 4x4 center diff lock.
Sent from my SM-N960U using Tapatalk
Everyone should get one regardless of whether or not they tow. It extends the life of the tranny. Cheap insurance.
Very true I agree 100%. I have an aftermarket one by Hayden when I dropped in an all aluminum Koyo radiator. I was told you should not get one that is too big. Mine is about 50% bigger than stock.
There are transmission cooler thermostats as well. Get a big ole cooler and with the thermostat, it'll only flow transmission fluid through the cooler when the fluid temp exceeds the thermostat set temp: Mishimoto Inline Oil Thermostat as an example.
AndiGarage
