johnbyebye
Hey everyone,
This is going to be a long post so bear with me. I would like some advice/brainstorming from you guys regarding my current transmission issue.
Almost 2 years to the day (January 2017) I had a used transmission swapped into my 4runner by a local shop. I bought the transmission from a wrecking yard and the shop installed it.
Fast forward to September of this year. I have not had a single issue with the transmission. I was going on a trip to Lassen NP and decided to change the fluid for good measure since I was approaching 30K miles on it.
I hadn't paid too much attention to the fluid level up to this point since there were no leaks. My main concern was how the fluid color/smell was holding up and all was fine. Well, the day I went to change the fluid I noticed that the level was significantly higher than the HOT fill line. Like one inch above it, no exaggeration. I checked it multiple times but the level remained the same. No worries I thought, when I change the fluid I'll just put less in. All seemed well.
On my way back from the trip to Lassen my transmission started to behave strangely. There was a large amount of drag on the engine when coasting and accelerating from a stop caused the transmission to slip. I checked the fluid and the level was fine (now at the fill HOT line) as well as the color.
A few days pass and I start hearing a whine coming from the transmission in addition to the drag and slipping. Just peachy. Thinking back to when I changed the fluid, I immediately added fluid and brought the level back to where it was above the fill line. Doing so did not resolve the whine however, my transmission no longer slips and works fine otherwise. I have already picked up another donor tranny and will install it when the weather improves. The whine has not gotten any worse.
I have not dropped the pan yet to take a look as I haven't had time.
I have a few questions for you knowledgeable folks about this entire scenario.
What would cause the fluid level to be that much higher than the fill line?
This transmission failed in the same way that the original one failed, the torque converter whining. The first one had almost no fluid in it as the drain bolt leaked. I suspect I had actually drained too much fluid out of the my transmission despite it being at the fill line.
The transmission was from a Federal emissions 4runner, but mine is California. As far as I know, the first donor transmission did not come with a pan, filter, or dipstick so all of these were transferred from my old one. Could there be a difference that affects the fluid fill line?
Shoddy work by the tranny shop?
I'm quite paranoid about this as presently I have no way of knowing how much fluid is actually in my transmission since the dipstick clearly can't be trusted. I am afraid of running into this problem with my second donor and I would very much like to not destroy it lol. Of all the problems I would have expected to encounter with a high mileage vehicle, replacing the transmission TWICE was not one of them.
Any ideas?
Thanks.
Any ideas?
Thanks.
