TRD PRO Roof Rack removal
bling
If I buy a TRD PRO and remove the rack (not a fan), do the holes line up to install the regular roof rack rails from the other models?
Yes, but the Pro rack uses Torx-style head bolts not regular bolts. Lots of videos on rack removal and installation, but just be careful to turn out the bolts a little at a time, alternating between each bolt. And use a ratchet wrench, not an impact driver.
I cannot stress enough how important it is to use the correct torx (T40) and not taking the bolts out until both are loose - else the bracket will rotate.
If you are not using T25s, you will strip the heads - do not fight the bolts. If they are not moving - heat them up to break the threadlock. If you try to force these out you will either strip the bolt or break the head off - plenty of people have done exactly that.
https://www.youtube.com/watch?t=392&v=PgPk-Q7iMJo&feature=youtu.be
Don't be this guy.
Yes, the hole line up. I did the opposite: removed the regular roof rack and installed the TRD which I got for a bargain on Ebay.
Just be aware that the sealing washers are very thin and prone to leak, thus when you swap out the racks, be sure to use some kind of added sealant to prevent leaks. I used a high quality, long life silicone sealant.
I cannot stress enough how important it is to use the correct torx (T25) and not taking the bolts out until both are loose - else the bracket will rotate.
Don't be this guy.
Thank you all for the solid info. I really appreciate it!
Don't be this guy.
It’s actually T40 that needs to be used. The rest is all correct! :)
