TRD rims on SR5
gman123
Quick question.
Do the TRD rims that are on the TRD Pro fit on a 2015 SR5?
I would like to swap out the rims, and re-use my tires since they only have 10k miles.
The upgrade the tires when I am in need for a replacement.
Thanks,
Quick question.
Thanks,
Yes they fit.
I had them put on my 2014 SR5, no issues at all! and factory lugs fit just fine.
shop around, I told my dealer the price I found online and they beat it by 10%, I got a great deal.
Thanks for the replies.
I will get them ordered on my next purchase.
So far I have done the following:
TRD skid plate
All weather mats
TRD shifter
Hood protector
Cargo cover
Exhaust tip
Kuat bike carrier
Cross bars
2021 trd rims on sr5
So i called my local dealer to get trd rims for my 2021 sr5 and the said they wont fit unless i get a trim kit with it? Anyone had this issue yet?
did they also tell you the best thing for you to do is to trade up your 2021 and put in another 20k for the 2022 trd off road vehicle that's on back order so you can get your TRD on?
The trim kit is probably 2 pieces of paper that the techs put over the front fender liners to let them know where to cut and make new holes.
May also involve trimming a little of the front bumper cover.
It is to my knowledge that TRD Pros have to have the fender liner mod and bumper trim done at port/dealership.
do not listen to the part department from the dealer they actually do NOT work on the cars or trucks, they can find the part # for you and see if the have it in stock thats about it some are more knowledgeable good luck
what tires do you plan on running? some people running aggressive AT tires experience rubbing with these rims due to the blocky and squared off profile these tires have, and the fact that some of these AT tires run large (falken)
I think if you run a less blocky tire like the michelin defenders you will be ok. when talking about rims and tires you need to think of offset as well. TRDs are pushed farther out to give a wider stance, but that creates a wider wheel arc when turning and why some people experience rubbing at full lock, typically in reverse
