Trim packers for rear springs
momo.75
Registered User
I was curious if any of you have used OME trim packers on the rear springs of your 4th gen? I have just a slight saggy butt so I was curious if you were pleased with them?
I have one OME 150PR10R on the driver side to try to get rid of side to side variance and really couldn't see a noticeable difference at all.
i put the tape to it today for some measurements. It wasn't as bad as I thought but still would like to adjust it a little. On completely flat surfaces it sometimes looks like it is sagging just a little.
FR - 38 7/8"
FL - 38 3/4"
RR - 39"
LR - 38 3/4"
I have one on the drivers side. Helps a little, but needs to be more like 1/2" thick to make it closer to level.
I just ordered some custom spacers from [MENTION=9]Jason B[/MENTION] . I went with 1" for driver side and 1/2" for passanger.
When I was on a 2.5 spacer lift in the rear, I was able to stack 2 of them 150s above the spacer, and still had the bump stopper installed with them also.
Jhunt
