USA-SPEC Bluetooth and Aux: Installation Followup
Hello all,
Just wanted to provide a followup on a recent installation for future searchers.
I recently bought and installed a USA-SPEC BT45-TOY in my truck.
Mine is a 2003 Limited, Factory Nav and JBL, no CD Changer.
The product itself works WONDERFULLY. Better than I could have ever imagined. When you're listening to the radio and a call comes in, it automatically switches over to phone mode, and you answer by pushing the "seek up" button (either on the Head Unit or steering wheel,) and push down to hang up. My only gripe is that the unit announces the phone number digits instead of saying "Call from Dad." Hopefully this is part of a future firmware update. When you're done with the call and hang up, just hit "FM" or whatever you were listening to.
In my installation, the unit replaced the nonexistent CD changer. Disk 4 is for the phone(Bluetooth), and Disk 6 is Aux Jack. I keep that straight by remembering that Aux and Six both end in X. When streaming music through Bluetooth (such as Pandora) it will display the song and artist on the screen, which is a cool touch.
The kit came with everything needed - wiring harness, instruction book (which lists all the vehicles it is compatible with) and a microphone. The only things you will need to provide are a dual-male ended aux cable, and a USB charging cable for your phone. I wish I thought ahead to get a black coiled-style usb cord instead of my bright white one for a neater look.
Edit: I ended up getting a phone mount with wireless charging, and ran that USB neatly to the port.
Since this project involves removing everything from the armrest, you might as well take this opportunity to replace any burned out bulbs in the area and if you're like me and forgot to take your pill, give everything a good toothbrush and q-tip cleaning.
The instructions say to install the box anywhere you like. Some suggest putting it behind the radio, but that makes it inconvenient for future cable swaps. I found that a perfect location is just below the hazard light switch. This way if you want to change out the cords, you just have to remove the storage cubby and climate control panel. I wonder though if I could move it lower and access the jacks just by removing the lower cubby.
The microphone included comes with a long cable -- roughly 80 miles of it. I ran the mic cable under the driver's kick panel, up the A-pillar, and across the headliner. I used some zipties for the lower part of it. Do this on a warm-ish day so that the plastic is a little more flexible. You should be able to just tuck it under the plastic with no tools. I used a rubber spatula to tuck it in. The mic has a clip and attaches easily to the rear view mirror. I did learn accidentally that the mic is directional and will pick up very well when pointed at the user. When testing it, I sat in the passenger seat and left it pointed that way. The next time I called my test subject, she mentioned that I didn't sound AS good. Moved the mic to point towards me and she said it was a world of difference. So that's good to know.
You can run the other two wires out however you desire. For my first run, I have them (usb charging and aux cord) coming out of the right side where the cubby meets the console and I coil them up inside the cupholder. I may make them come out of the cubby though so I can coil them up and hide them when not in use. I'm a big fan of no clutter.
So, a summary:
Great Product. Easy installation if you can follow directions well.
Technologically SEEMS complicated but easy to get used to.
Economically a great option if you don't want to lose OEM look or spend a ton on a replacement unit.
Gripe: Reads out phone digits instead of phonebook name.
Search around for a good price, I found a great deal through Amazon.
1 Year Followup
Ok, maybe more like 10 months, but here are some observations:
1) I wish there was a firmware update which would allow the unit to read my contacts list. That way it would announce "Call From Jim Smith" instead of saying "Call From... Three Zero Nine Five Five Five One Two One Two." It does not stop speaking when you answer the call, so you have to sit through the whole reading and say "hang on, gimme a second...." and chat when she's done reading the number. There is something in the settings about this, but the options are "Read the full number" or "Play a very silent & nearly useless little musical tune as a ringtone."
Edit: I have contacted the manufacturer and they are not interested in making this update. You can, however program it to not read this info and simply go by your phone display, which I did.
2) There is a HUGE volume difference between the Bluetooth and everything else in the radio. So make sure to always turn the volume knob WAY down after a call, or when you switch back to FM, you'll get blasted. I have not looked in the instructions to see if this can be adjusted somehow.
3) Seems to take F O R E V E R to connect with a phone sometimes. Like if someone calls me and I realize I forgot to turn bluetooth on, it's sometimes a full minute or more of back and forth before it connects and functions.
Edit: This turned out to be my phone. When I got a new one recently, I realized that it connects nearly instantaneously.
That's it. At this point I'm still happy with the unit. I sometimes wonder if I should have put the money towards a whole new aftermarket unit instead of this, but it suits my purpose and I wouldn't recommend against buying it.
Would you be able to run the AUX and USB along the console and into one of those “blank” switch replacements for a clean install?
Yes - I believe that would work perfectly. The only reason I didn't is because I didnt want the cords running from thr console to.the dash where I clip my devices. I figured they would get caught in thr gearshift or I would bump it off with the flip-tray.
I installed 1 years ago in my 06 Civic Si. Like you mentioned, it's worth living with if that's all you need.
The only saving grace is keeping your OE head unit.
So for others who are looking into this:
I have factory JBL w/ nav and bluetooth handsfree. I was looking for something that retains all the oem components but also allows my phone to connect and play music while charging (newer iphone doesn't have headphone jack) my solution was the GROM USB unit (not the bluetooth) This plays music through the CD changer from a usb cable and I can switch back and forth from the AUX connection. When playing music and a call comes in, I can answer from my steering wheel buttons and the music stops, when I hang up, music continues!
Just wanted to add to this conversation with another option that works for some specific needs.
DJNutshell
