vibration/humming sound
01thunder
between 50-60, vibration/humming sound starts, let off the gas, sound goes away. give it gas, starts again. very annoying. it's not the tires.
Not sure if this has been asked before but is there a reason why a driveshaft lacking grease would lead to vibration only within a specific range such as 50-60mph that we typically hear about?
betwee 50-60, vibration/humming sound starts, let off the gas, sound goes away. give it gas, starts again. very annoying. it's not the tires.
Do you daily drive your 4runner and one day it suddenly started to vibrate within that speed range or was any work done on it and then you noticed it?
i just noticed it today. I've had the truck for 3 years with no problems.
It's always been the u-joints in my experience, particularly when the problem gets worse under load. (2 T4R, 1 Taco) You can't always tell by inspecting them either - there are several threads where various experts looked at them and called them good only to finally change them and solve the problem later.
So how do you fix this? Blast some grease into the zerk fitting? What kind of grease?
Sent from my Nexus 5 using Tapatalk
Is there a reason why a bad u-joint would only cause the vibration under load in a specific speed range of 50-60mph that we usually here about?
Edit: i get the under load part but never understood why it occured in a specific speed range and outside of that range the vibration was absent.
Dunno exactly, but that's how they fail.
It's a fairly straightforward fix. I had a driveline shop replace mine and balance the driveshaft for about $175.
i may go the route of replacing U-joints. does anyone have OE part numbers or where to get quality replacements? mine aren't greasable and the front one is showing signs of the sealed grease oozing out.
Having no grease-able u joints, then your runner must be a 2WD??
This should be the part # (04371-30041) for the joints. But double check with your local dealer.
Or I would get some grease-able u joints from Spicer...
spicer doesn't have any greaseable ones for toyota.
AndiGarage
