Weird dash noise 2007 V8 SR5
solution 3, take it out and put locktite on the worm gear. Problem solved forever for about $5. and 1 hour of time.
I just did it, it was not that bad of a job. Just have to get the white rotating gear off of the actuator and make sure it stays in time. Hint: be sure that the setting is on "dash vent w AC" before you remove it and it will be easy to retime the gear.
Here is a video on how to fix it forever:
https://www.youtube.com/watch?v=s9S5B1Dn3j4
Oh sure if you wanna be all Fixie and fix stuff then I suppose that would work
seltzernator
