Westin Push bar vs Front Marker lights...
Mz Rikki
I have a 2002 4Runner SR5 and I have a Westin push bar (Prius Pusher) mounted to the front. It is aftermarket and it was on there when I bought the truck. I have to change out the 2 front marker lights and I watched a video on how to do this. I was wondering if anyone else has this push bar on the front of their 4Runner and if so, can you change the marker lights without removing that??? It is not critical, but at some point, I will have to replace the headlights too.
The Prius Pusher looks great, but is in the way!
Thank you for any input on this!
Rikki
HELP!:rant:
if you're talking just bulbs, all you change all of those from inside the engine room. If you need to replace the actual housings for those bulbs (the whole headlight and marker light), it would be much easier to just take the "prius pusher" off.
I like that name... mind if i borrow it? :lmao:
so you're saying I don't have to take off the marker housing to change the bulb? Ive been doing this all wrong for the last five years! :rockthrow:
Take the air cleaner housing out, the battery, the radiator, the core support, THEN you can get to those pesky markers without taking out that one screw.
:evil:
hot damn. make one mistake and i might as well have told someone to drink bleach.
listen to those guys up there. they know. I've only changed mine once pre-brushguard, and I did just take my marker lights out. But without looking at my truck, I figured you could still get to the plug without tearing off the front of your truck like some members have described.
My bad.
:hiding:
DJNutshell
