Wheel Question
pokeyman
I plan on getting a set of 2002 Tacoma 16 inch wheels for my 98 4runner. I have 16 inch wheels already just want newer ones. Will these Tacoma wheel fit right on? Thanks
They will bolt on, but may have a different offset (how far the wheel sits inboard or outboard). 4runner stand is 15mm, Tacoma ranges from 4mm to 30mm ~ the bigger numbers mean the wheel is tucked into the fender further, the smaller number the more chance the tire will "poke" out past the fender.
Toyota Wheels Rims Wheel Rim Stock OEM Replacement
Look there to see if you can get the info based on the looks of the wheel. If it doesn't have the offset on that page, search the part number and you should be able to find the offset.
Or just slap them on and don't worry about it, it's worked fine for lots of people. I'm just super uptight about how things are Supposed to function together.
As long as they are 6-lug Tacoma wheels from that year, they will work fine. So, need to come off a PreRunner or 4x4 Tacoma.
-Charlie
seltzernator
