When would you add a refrigerant?
Jacobzky
does it help the ac to blow cooler air? id asked because i have this 00 civic for 7 years now, and i thought its time, but do i need to add a refrigerant?
Refrigerant
If you have an '00 model car, chances are that some of your A/C refrigerant has slowly leaked out during the past seven years. Your Civic should have R-134a in its A/C sytem, since most every US-market car built after 1993 uses this type of refrigerant.
R-134a replaced R-12 {known to most of us as 'Freon'}, which is almost impossible to find anymore. You also must have EPA certification to purchase R-12 nowadays.
The good news is that R-134a is relatively inexpensive and you can buy it at any auto parts store without having EPA certification (unlike R-12). Wal-Mart sells a recharge kit for about fifteen bucks, which lets you recharge your system in your own driveway without any special equipment.
I have never used one of these kits, but I know they sold quite a few of them at Wal-Mart. The shelves were full of them about a month ago, and they only had about a dozen cans left as of yesterday. Paying $15 and doing it yourself beats the heck out of paying $100+ for a shop to do it; that's for sure!
According to the directions, you run your car until it reaches operating temperature, crank the A/C to "MAX" and then attach the recharge kit's hose to the low-pressure valve of your A/C sytem. Fill it until the gauge registers the proper pressure in the green zone and then it is done.
Provided you have no other defects with your A/C system, you should be cool the rest of the summer. Even if you have a minor leak somewhere, I reckon it is more economical to buy a can of it once or twice a year than to spend a few C-notes for a mechanic to diagnose, 'dye test' and re-pressurize your entire system.
Let us know how it works!
I just picked up a can of refrigerant and it had a guage with it for $16 w/coupon from Checkers.
I had to do mine twice but it has cooled up my system by quite a bit. Just make sure you do it when temps are in the mid 70s for most accurate readings.
Thank you, i will try it and see the result.
never have a problem on my AC (knock on the wood) but thought it has be cooler than what its blowing right now
thanks again.
it worked, blows cooler, but i just aaded a can (14oz) , the sticker on the hood says 22 oz. if recharging.
but yeah for the first time in 7.5 years my AC tasted a new refrigerant. and it blows cooler now than before. ill try to add some more (but dont want to overfill) .
:bigok:
Tx470
