Where can I get this bolt? DIY Diff Drop Kit
BOFFROAD
I am putting together my own Diff drop kit for when the lift comes. Has anyone else done this? If so, where did you get longer bolts for the differential? I have checked Home Depot, Lowes, and ACE.
I need
Length ~17cm
Diameter 14mm
Threads M10x1.5
Grade 10.9
If I cant find this I will try looking for a standard bolt close to it and will have to use a different nut.
I need
Length ~17cm
Diameter 14mm
Threads M10x1.5
Grade 10.9
Here are those dimensions in redneck units which may be easier to find. :D:nerd:
1/2" diameter (exact: 0.55")
6 - 3/4" length (exact: 6.69")
Find a 1/2" nut and you're set.
I'd stick with the same Grade for sure.
