Which winch?
davehaynes1
Hi guys.
I have a '93 4runner 3L V6.
Pretty standard apart from back seat removed and a big roof rack and tool box added, so I guess the weight is pretty much as it was from the factory .
I'm looking at buying myself a winch but have no idea what size I would need . I'm on a budget so don't want to buy one too big that I won't need.
Figure prox 2x the vehicle's weight. You don't want something too strong, because you want the winch to fail before your frame does ;). An 8000-9000 pound winch would be perfect.
Hi guys.
kevin says 2x, but I think the general rule is 1.5x. either will work. I really like my Rugged ridge 8500. but there are MANY winches out there in the 8-9k range for $250-500.
the RR 8500 is pretty quick at almost 30fpm. I think I have seen it on amazon for around $250, less than $300 for sure.
my RR10.5 doesn't sound much slower, at almost 20fpm. but in real world use, its noticeably slower. id rather have the 8500/30fpm 9 out of 10 times.
there is some truth to that.
though, with some attention and smarts, its not really an issue. the biggest problem I see with the larger capacity winches, is they are slow. typically the stronger they get, the slower they are.
a faster winch is better than a slower one. you can always overcome the limited pulling capacity of the weaker winch by using a snatch block. but, theres no way to speed up a slow winch.
in fact, I recommend a block for ANYONE using a winch. it really should come with all winches sold, as a default option.
alexaturner
