Whiteline W73420 20mm rear spring isolator spacer
Anybody have any real world experience with the Whiteline W73420 20mm rear spring isolator/spacer. I currently have a worn out 2002 SR5 and I want to get AC Delco 99 tall springs and also use this 20mm spacer on the rear. Then I would like to go with the 5100s to lift the front.
No experience with it, but it sure sounds 100% better than stacking 2 OME 10mm spacers on top of each other as Ive seen some do.
I say go for it! The amazon image makes it look like it'll fit. Should go between the spring and bumpstop
Yea it really sounds appealing since I don't want to make the rear any more stiffer at all, in any way. Since I have a 2002, this spacer and the early tall spring should give me a decent amount of lift over where I am right now without going to a stiffer spring.
peacefulpiranha
