Will 108mm center bore wheels fit my 2000 4runner?
DPR64
I have a set of wheels that I use on my FJ62 that has large hubs on the front and the wheels thus have a 108mm center bore.
I want to use them on my 2000 4runner that has wheels with a smaller 106mm centerbore. Will the 108's work PERFECTLY on the 4runner even though they are not hub centric as the 108mm is larger?
Im not positive, but this might at least give you a direction to search...Im under the impression you will need a spacer ring.
Hub Rings
2001ATL
