Will 2003 4th gen T4R wheels fit my 2002 3rd gen?
Jenesis
Hi Guys...Need your assitance on finding out
1. Will these wheels fit my 2002 4Runner SR5? (Stock suspension)
2. Are the center caps METAL? (Planning on p/c the wheels)
3. 265/70/17 will rub or is it cool?
Thanks Fellas!
I would assume the bolt pattern is the same, and rubbing shouldnt be a concern. 265/70/17 size out about the same as a 265/75/16 which doenst rub, so you should be okay.
I was running 4 gen wheels on my runner when I bought it but when I lifted it and went to put 255/80r17 and they rubbed on the upper a ARM so you will run in to issues when you up grade to larger tires I ended up getting some aftermarket wheels to solve the issue
