Will 22 x 9.5 black rhino pondora wheels fit on my 2003 toyota 4runner limited? Wheels have a +25mm offset, and the tires I plan to use are nitto 275/40s.
Thanks a lot! I was more concerned with the width of the wheel fitting because I have heard of issues with the black rhino pondoras fitting on my generation 4runner in the past
I don't see why it won't fit? You can have 285 45 r22 for tires and it should be fine. I have no problems with it unless I do really hard lock to lock turns, then they rub a little on the liners
Thanks, I don't see the issue either I was just informed that with the 9.5 width and the 25 mm offset there could be an issue fitting without using a spacer which is what I wanted to avoid. What year is your 4runner and what size are your wheels including offset?
