Will these gears fit?
runnyrunnerton
I ran across a guy selling 4.88 gears out of a 86-95 Toyota truck. They fit in a 7.5" clamshell and I was wondering if I could swap the gears into my front shell or am I even luckier and can I swap the old assembly in altogether? I am setting up for 4.88's front and rear and I don't plan on installing until I have matching sets. Just wondering if these will fit.
Possibly.
Your front differential is a 7.5" clamshell differential.
Your rear differential is an 8" differential.
Here is a helpful source. Look up your '97 and his model year pickup.
http://home.4x4wire.com/erik/diffs/#v6/turbo
Probably not the answer you wanted. I am not sure so I don't want you to pull the trigger on heresay. In terms of gear ratio, I've always heard:
You have 295/70 R17's so roughly a 33" x 12" tire. 33" with a 4.88 gear ratio is proper.
Mainly Pavement usage: 4.88's
Mainly Trail usage: 5.29's
I've paid my dues with the search feature and am dead set on sizing.4.88's as I live in fl and offroad infrequently at best.... I'm just worlds away from calling ECGS and doing the full setup lol!
The front clamshell will not swap over, they changed in '96. The 7.5 ring and pinion should swap into your existing clamshell, but have your installer look up the part numbers and make sure before you pull the trigger.
If you get really stuck, ZUK at gearinstalls.com has always answered my emails when I pester him with questions.
edit - ack! Are they factory 4.88s? If so, they may not work for you at all, the factory 4.88s in the second gen had a unique carrier. Maybe the carrier will swap over into your chunk? I don't know. You've got more research to do.
your rear is not a clamshell.
if its a V6/turbo 8" rear it should work.
for the front. i have confirmed that a 95 gear set and a 2000 gear set for the clamshell have identical part numbers in the catalog
True. You cannot swap out the entire clamshell but you can however swap the guts.
i have also confirmed that the V6 95 (2nd gen 4runner) has identical part numbers for the rear gear set as well.
so yes. it should work
i have also confirmed that even w the 22re, the gear sets have identical part #'s between 2nd and 3rd generations.
scoop em up
and guys, here is the link that I used . . 1993 Toyota 4Runner JPP-4 WHEEL DRIVE 11793 41-01 Rear Axle Housing &
the reason i like this one is because you can put your VIN in to ensure you are choosing the correct parts. you can also choose by year make model trim line, engine, drivetrain, etc.
PERFECT FOR CROSS-REFERENCING.
if you click on the little "MORE INFO" button at the top of the parts list, there is a box that pops up that will show you a blow up of all the parts in the diagram (WITH PART numbers - unlike most the other toyota parts sales sites).
Base: "Niner, niner. Tango bravo echo delta. We have confirmation of a matching differential. You are clear to engage."
OP: "Roger that. Engaging differential."
<object width="100%" height="25" class="hark_player">
<param name="movie" value="http://cdn.hark.com/swfs/player_bar.swf?pid=nrxrwxkfdt"/>
<param name="allowscriptaccess" value="always"/>
<param name="allownetworking" value="all"/>
<param name="wmode" value="transparent"/>
<embed src="http://cdn.hark.com/swfs/player_bar.swf?pid=nrxrwxkfdt" type="application/x-shockwave-flash" allowscriptaccess="always" allownetworking="all" width="100%" height="25" wmode="transparent"></embed>
</object><br/>
<a href="http://www.hark.com/clips/nrxrwxkfdt-were-you-calling-from-a-walkie-talkie" style="font-size: 9px; color: #ddd;" title=""></a>
Sorry. I'm tired.
QSL. you are clear. haha.
if you know HAM. then you know QSL
Haha! I just signaled it through the CB.
I feel like Smokey and the Bandit. Some here might not be old enough.
<embed src="http://cdn.hark.com/swfs/player_bar.swf?pid=kpngszkhcp" type="application/x-shockwave-flash" allowscriptaccess="always" allownetworking="all" width="160" height="25" wmode="transparent"></embed>
The front diff gears are NOT the same even though they are both a 7.5 clam shell design. The Taco/3rd gen uses reverse cut gears. The rear V6/Turbo diff is the same though
No you cannot. The 7.5" in the 86-95 models is a low pinion diff. And, its not even a clamshell. Its a solid diff with a removable diff cover.
The 96+ 7.5" is a High Pinion, clamshell design. It will require REVERSE cut gears to work. Its apples and oranges and will not work.
You need 7.5" Reverse cut 4.88s.
The only thing that will crossover between the two is a locker/carrier. That is it.
IN THE REAR ONLY:
They will crossover from V6 diffs into either the Elocker or standard V6 carrier.
No you cannot. The 7.5" in the 86-95 models is a low pinion diff. And, its not even a clamshell. Its a solid diff with a diff cover.
The 96+ 7.5" is a High Pinion. It will require reverse cut gears to work. Its apples and oranges and will not work.
What do YOU know Scotty!
:behindsofa: ..haha
On a serious note, thank you for correcting me, I was looking at the wrong differential on the page.
IN THE REAR ONLY:
Beat you to it
smiley-na-na-1.gif~original
D'Angelo
