Will this set up work with stock UCA?
toomuch50
Any issues getting caster and/or alignment back in spec with the following set up? Want to check before I get the last piece I need for install. If there are issues I will sell the front spacer and go down in size with no rear spacer. Thanks in advance. I usually don't post and find all my answers by reading but this wasn't clear to me as there may be issues with over 3" of lift.
Fj springs/shocks front and rear
Front 2.5" Revtek spacer (swear they only had 3" but this measures about 1.25")
Rear 1.5" daystar spacer (only piece missing)
Cooper Discoverer ATP 265/70/17
I just installed my toytec ultimate Friday, have general grabber 265/70/17 on stock wheels and it clears stock uca's by about a half inch, you should be good!
Appreciate the response but I'm concerned about getting caster back to an acceptable range. That is good info for clearance issues though. I just don't want the vehicle wandering with bad caster. Thanks again!
Youll most likely notice it wandering more, but I dont think it should be too bad.
For 7 months I ran with stock UCA's all was well, wandered a little but definitely doable! Was happy! Saturday I installed some LR UCA's I haven't driven many miles but I can tell a difference! You will be fine running stockers!
Jhunt
