Wrapping Winch Solenoid
Chim
I have seen a couple people wrap their winch solenoids to save mounting space instead of having the large plastic winch box using some sort of rubber shrink wrap.
Has anyone done this that can shed more light on the process and what product they used?
Thanks!!
Thanks!!
interesting concept. I would think there would be an issue of it overheating if it were wrapped up that way.
do you have any links to any that have done that?
you might consider getting a winch with a contactor, instead of a solenoid. they are much smaller. or, get a contactor for whatever winch you choose, if it doesn't already come with one.
it would be much easier to find a space to mount it, or even mount it in a smaller box. my winch uses a contactor, the winch control box is about 5x larger than it needs to be. its not an issue where mine I mounted, so I just use the original configuration.
edit: I just checked that link. that is a contactor, not solenoid. though, my concern about the heat remains.
[MENTION=122940]ramonortiz55[/MENTION] I saw you did this too... did you just use electrical tape and how has it held up?
I ended up placing it inside the box - It was in tape for a couple of weeks.
The box is currently mounted on the inside of the engine bay, to the right of the battery against the "inside of the fender"
AndiGarage
