WTB: E locker body harness
3rdgenfan
I need the body harness and all necessary wiring to wire up my e locker. I have the switch and ecu and the harness for the rear axle. I just need everything needed to wire this all up. Shipping to 80916. Please send me pictures if you can.
you wouldn't want it
the body harness that you want is also connected to other wires and you'd have to wire non-elocker related things.
option 1 - if you are pre-wired and want to use the cpu - create your own body harness ( Retrofit Electric Locker )
option 2 - if you are not pre wired, you should buy a complete harness (bypass locker cpu - elocker to switch)
i am also going through this now. good luck!
Is it possible to use the factory switch or you have to use the supplied one?
tobasko556
