Xenon HID / LED Question
T4R_KAI
Couldn’t find a definitive answer on this.
Do I need the PWM module for the HID low beams?
Also, for the LED high beams, do I need both the PWM module and the DRL LED driver or just the LED driver?
No for HID.
Yes for high beams unless you do the DRL driver to eliminate the flicker. If you run a PWM without the DRL driver, it will run your DRL at full blast making a bit too bright for a DRL.
No for HID.
Okay thanks. I wasn’t sure if the DRL Driver would eliminate the flicker.
Are there options for LED hi-beams that keep DRL functionality *without* full brightness or flickering (other than xenondepot which is $120 + $60 for the DRL driver)?
MaximussK
