XTR LP License Plate Reverse Light - GROUP BUY!?
No offense but what good is the warranty when you don't honor it? I was supposed to be receiving a replacement festoon bulb from you guys months ago and still nothing...
I am unsure on what had happened in that situation, do you have access to your Order Number/Email Ticket Number associated with your order? I assure you - if we owe you a bulb, we're going to send it out! :) The order might be stuck in the old system, as we have recently updated our website + Backend software to an all-new platform, it's brought on some troubles here and there so this may be due to why you didn't receive that bulb.
PM Me if you would like and we'll look into it again!
Maybe if you guys can put together an install video or something, we could get a few more people in on the group buy (those who might be on the fence).
I'm looking around for a 4Runner to install on, I think you guys may be in-luck! I'll see what I can make happen and will report back.
Id be interested depending on price - but usually the vendors here post a range of QTY = Discount%. Can you list your goal for 15% or 20%?
That's what I'm trying to feel out with this post, if I were to roughly take a guess, it would be something like so:
10+ ppl = 10% off
15+ ppl = 15% off
20+ ppl = 20% off
These are loose guesses, I don't have the full permissions to make the determination so it's something that would have to be approved through Bossman. I just know the more ppl onboard, the better the Savings are going to be!
I would not consider this a “simple” mod on a 5th Gen. If you’ve taken your back hatch apart before you’ll know what’s involved in fishing a wire harness through the hatch door, through the rubber hatch boots, into the headliner and down into the rear brake/reverse light access panel. Not super difficult but it will take you a good amount of time and determination. (As in installing the Ultimate Camping mod). And you’ll have to drill thorough the hatch and then seal it. Set aside a long day or two to do it.
It would probably be a good idea for some member to act as a guinea pig and get a light assembly, set it in the proper position, temporarily connect it to +12 volts at night, and see if it’s worth the effort to install it. Take photos and write up a review in this thread. Maybe XD could send a complementary one out for review. Then we all can decide on a group buy.
Edit:
Some suggestions for XD: The wire length of 1.5 meters is not enough for the 5th gen 4R. You’ll need at least 2 meters for all the routing and strain relief that needs to be done. Plus the twin lead wiring is rather fragile for this. It would be better to include a two conductor plastic coated cable that would withstand all the abrasion, bending, and tugging that will be done when fishing it through the 4R hatch and rear pillar innards.
Wow alot of work but still interested as this would be a great addition to the back up lighting. Thanks for the meaningful insight on how it would have to be done
Forgot to ask before, does this have a light underneath that will illuminate the license plate as well? Unlike the Tacoma or tundra, 4runners stock license plate lights will be blocked by this bar.
Sent from my SM-N975U using Tapatalk
Xenon Depot should comp someone here a light to test fit on their 4R license plate to check out how well it works and point out any problems.
There currently are 0 reviews of the product on their website.
XTR LP Reverse Light System
I offered to be a tester, I've got more lights on my truck then is reasonably necessary and I know what will be necessary to install it properly. Fell on deaf ears I suppose. My stock license plate lights, even after upgrading them are dim. I was looking at this or the mini RTL from Baja designs. I have the full sized RTL up on my rack and I love it. I actually just upgraded to the RTL-S with turn signals so when that comes in I'll get it installed and see if I want a matching mini on my license plate or if this will work better.
Still would like to know about this before purchasing please
Will this work with a license plate holder?
It won't block the License Plate lights at all! There's plenty of space to clear the XTR LP system when bolted in. :) It'd have to be Klondike-bar sized to cover those things up!
H.Sikina
