Xtreme LED Pro Kit Review - 5th Gen Toyota 4Runner
Any pictures of proper positioning for clocking the low beam Led’s? I pulled up to a wall last night and noticed my drivers side headlight patters was much more dim and scattered then the passenger side.
It's stated throughout the thread. 3/9 o clock.
Ganj - the ballasts in these kits are quite reliable, whats going on with yours? Is it not lighting up consistently, or not at all? Have you installed the relay harness thats supplied with the kit? Please let us know so that we can assist with a replacement, or a discount on an XTR LED system if thats what you prefer - we'll do whatever need be to ensure youre taken care of!
I got my Xenon order after 3 weeks. I must say it's slightly confusing.
I ordered the 9005 Xtreme LED for the HI-BEAMS & DRL with the additional "DRL module" and I also ordered the Xtreme HID kit with Philips bulbs for the LO-BEAMS.
Inside the "9005 Xtreme LED Pro" kit for the highbeams was a box labeled "LED driver" (which I'm figuring out isn't needed for this install)
With the HID kit came the 2 DRL Driver kit, which was needed for the HI's.
So do I need the LED driver that was in the Hi-beam kit for the HID lo's?
Do I need to use the included wire harness to power the HID lows directly off the battery? I didn't use them and everything seemed to come on just fine. I remember reading something about it helping in extreme cold weather so the HID got a better voltage? I'm in south Florida and not in extreme cold very often so can I skip it?
Basically I have 2 wiring harnesses leftover and 2 "LED driver"s leftover.
Just making sure I did everything right...
Jhunt
