Cam ring and vane plates removed from rotor, also notice the snap ring that holds the rotor on the shaft, it is partly unseated so you can see it. I call myself checking the pics as I went but my eyes must be worse than I thought, sorry about the blury pics.
Front housing with the shaft seal removed,
Inspection instructions from the FSM,
Pump shaft to housing check, I used my digital calipers for this.
Vane to rotor check,
Vane plate check,
Random picts,
If anyone has any suggestions as to how this is arranged please feel free to speak up because I'm not real good at this. I will have to take some more picts and show how I prepared the parts for assembly.
99 4runner SR5 3.4 auto, in the rebuild/build process
2wd to 4wd, SAS, 80 series LC axles and transmission
My Build,
http://www.toyota-4runner.org/3rd-ge...ild-build.html____________________________________________
"The significant problems we face cannot be solved by the level of thinking that created them" Albert Einstein
