Old 03-24-2018, 10:56 AM #1
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
rkntoy's Oil Changes and Broken Things
Too many build threads around so I figured I would start a thread on my oil changes and things I break. If there are questions on my mods I will answer those here as well so that I don't have to keep replying to the same PMs.
Thanks for watching - next oil change in 2,855 miles.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 03-24-2018, 11:01 AM #2
rkntoy's Avatar
rkntoy's Avatar
Anyone broken a CV in this spot before? My only Moab carnage.
rkntoy's Oil Changes and Broken Things-20180323_172334-1512x2016-jpg  rkntoy's Oil Changes and Broken Things-20180323_171908-1512x2016-jpg  rkntoy's Oil Changes and Broken Things-20180323_171903-1512x2016-jpg
Old 03-24-2018, 11:18 AM #3
audiness's Avatar
audiness audiness is offline
audiness will become famous soon enough
audiness's Avatar
damn, were you able to lock the center diff and drive home, or did you have to trail-repair it?
audiness is offline   Reply With QuoteReply With Quote
Old 03-24-2018, 04:39 PM #4
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
Center diff rkntoy's Oil Changes and Broken Things Rkntoy has a real 4WD rkntoy's Oil Changes and Broken Things
Also interested if you needed to replace it to get through the trail you were on though! That's a pretty crazy break.
Let's hear more about these oil changes though. Lol
How often to you change? And what oil do you use? That should get some people fired up.
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 03-25-2018, 02:57 AM #5
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
Weren't we just talking about IFS, 37's, and breaking CV's in some other thread recently? I'm guessing even smart wheeling didn't have a chance of stopping that failure.
I was hoping dual cases would help prevent that sort of thing but maybe the extra torque will make it happen more not less? What where you doing when it snapped?
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 03-25-2018, 11:32 AM #6
rkntoy's Avatar
rkntoy's Avatar
I like 5-30, late nights in the snow, and wind through my half doors.
Satoshi grill anyone? Should prevent premature cv issues
Old 03-25-2018, 11:42 AM #7
rkntoy's Avatar
rkntoy's Avatar
Not supposed to break there. CV cage should have gone first. We will see if I can break it there again in the future.
Picked a bad line on a steep (read STEEP) downhill on Hell's Revenge and was backing up to realign. Most of the weight was on the front tires. Should have let it creep at idle but gave it some gas because I was concerned about what would happen if I rolled forward.
Funny thing - it was such a jagged break mostly inside where the wheel bearing is it still worked to drive the wheel. Thought I had broken the CV cage - nope the CV and wheel still turns. Then I thought it was the gears in the manual hub - nope they looked in great shape. Convinced myself it was the locker releasing when I went from forward to reverse under load. Only indication of something else was that the locking hub was hard to turn.
Still drove the rest of the trail and back to Bend.
For 6 days in Moab on 37s I will take it.
Old 03-25-2018, 11:50 AM #8
rkntoy's Avatar
rkntoy's Avatar
It kept for 3 weeks including finishing Hells Revenge and the drive back to Bend from Moab.
Trail swapping these is easy-peasy compared to some of the axle shafts in my old straight-axled rigs. Usually 15-20 minutes. If you have not done the manual hub swap it is even faster.
Old 03-26-2018, 12:00 AM #9
BigFishAllDay's Avatar
BigFishAllDay BigFishAllDay is offline
BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about
Too many build threads around...
Definitely agree, but...
So far this thread sucks dog farts. At least post a pic of the rig in Moab, as mentioned below. I would definitely enjoy seeing some pics/info on your setup.
2001 SR5 Sport Ed. S/C'd V6 Auto 4wd (< Click for Build) ....everything but a kitchen sink (it's on the "to do" list)....
2003 Tacoma SR5 S/C'd V6 5-spd 4wd (< Click for Build) ....boost, armor, lockers, gears, etc....
2008 Sport Ed V6 Auto 4WD (< Click for Build) ....the Grocery Getter OEM+ build....
My Write ups: T-Case Leak? - 231mm TBU - Rear Axle Seals - Trans. Cooler Install - Suped Up Air Comp - Big 3
BigFishAllDay is offline   Reply With QuoteReply With Quote
Old 03-26-2018, 11:26 AM #10
rkntoy's Avatar
rkntoy's Avatar
OK - was in lead most of the time so not too many pics of mine.
rkntoy's Oil Changes and Broken Things-mvimg_20180301_170225-jpg  rkntoy's Oil Changes and Broken Things-mvimg_20180301_170227-jpg  rkntoy's Oil Changes and Broken Things-mvimg_20180301_125548-jpg  rkntoy's Oil Changes and Broken Things-mvimg_20180301_160422-jpg  rkntoy's Oil Changes and Broken Things-mvimg_20180301_160424-jpg  rkntoy's Oil Changes and Broken Things-mvimg_20180301_160618-jpg
Old 03-26-2018, 11:28 AM #11
rkntoy's Avatar
rkntoy's Avatar
And only one from Saturday after slapping my rig back together.
rkntoy's Oil Changes and Broken Things-screen-shot-2018-03-26-7-35-52-am-jpg
Old 03-26-2018, 12:45 PM #12
I didn't know you took the KO2's to Moab!
What do you think of them so far?
Old 03-26-2018, 01:23 PM #13
rkntoy's Avatar
rkntoy's Avatar
Love them 90+% of the time. I am getting an "off-road" set of tires and mounting them up on beadlocks - especially for times like this:
rkntoy's Oil Changes and Broken Things-20180324_141448-2016x1512-jpg  rkntoy's Oil Changes and Broken Things-20180324_141524-1512x2016-jpg
Old 03-27-2018, 12:07 PM #14
rkntoy's Avatar
rkntoy's Avatar
Dual Case Install
Link to my dual case install and nail through finger pic.
rkntoy's Really Slow Dual Case Install
Old 03-27-2018, 12:34 PM #15
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute JZiggy has a reputation beyond repute
JZiggy's Avatar
Was this an OEM CV?
JZiggy is offline   Reply With QuoteReply With Quote
rkntoy's Really Slow Dual Case Install rkntoy 3rd gen T4Rs 47 06-11-2017 08:51 PM
rkntoy Feedback segafan1989 Feedback on Sellers & Buyers 0 12-05-2016 09:31 PM
May have broken some things .. help! dunktap 3rd gen T4Rs 14 11-17-2015 04:26 PM
Its the little things 20034RunnerV84x2 4th Gen T4Rs 4 07-04-2012 10:20 PM
ARB broken, mud and lots of broken parts sibanez 4th Gen T4Rs 14 08-02-2006 06:59 PM
