Old 02-28-2011, 10:49 PM #1
OBXRunner's Avatar
OBXRunner OBXRunner is offline
OBXRunner is on a distinguished road
OBXRunner's Avatar
Changing Bulbs in A/C unit!
Have you ever had a bulb in your AC unit go out. It can be pretty annoying. This write up describes the way to fix that issue by replacing the bulbs.
Parts needed:
Part number: 81850-35040 Description: lamp assembly These are the larger ones with the white base-these go in the display
Part number: 81850-35050 Description: lamp assembly These are the smaller ones with the black base-these are for the buttons
Pic of light bulbs used in fixing AC display
This is my before shot. Notice that the display is completely burned out and can not be seen at night. The lights for the buttons were fine but I went ahead and replaced them while I had it all dissassembled.
BEFORE: AC unit before-display lights not working
Step #1: Disessemble the dash.
Step #2: Unscrew the screws holding the AC unit to the vehicle and carefully pull the AC unit out,
Remove the AC unit by unplugging the cables.
Remove the two small screws on both sides of the AC unit.
Using a screwdriver, carefully separate the black front from the white housing by carefully prying on the tabs. They are plastic so be careful!
Remove the light bulbs by slightly twisting the bulb to the left with a screwdriver and then pulling them out.
Replace the light bulbs and reassemble.
AFTER: AC unit after-display lights working
Hope this Helps!
2000 Limited 4Runner
OBXRunner is offline   Reply With QuoteReply With Quote
Old 03-01-2011, 01:06 AM #2
GottaBeTRD's Avatar
GottaBeTRD GottaBeTRD is offline
GottaBeTRD is on a distinguished road
GottaBeTRD's Avatar
nice write up! for those of you that want a custom color the little bulbs in LED terms are a neo wedge type III or 3mm bulb and the bigger ones are Neo Wedge type 4 or 4mm
01 SR5 SPORT
Many mods done, Many more to come
Build Thread
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
GottaBeTRD is offline   Reply With QuoteReply With Quote
Old 03-01-2011, 02:07 PM #3
4ganger's Avatar
4ganger 4ganger is offline
4ganger is on a distinguished road
4ganger's Avatar
this should be added to the FAQ if it is not there already... :-D
4ganger is offline   Reply With QuoteReply With Quote
Old 03-01-2011, 08:18 PM #4
OBXRunner's Avatar
OBXRunner's Avatar
haha thanks! just thought alot people would like to see what they are getting into before the start tearing the dash off!
Old 03-01-2011, 10:32 PM #5
4ganger's Avatar
4ganger's Avatar
Interesting... I have a 2000 SR5 Sport but my A/C unit looks totally different. I don't have the screen like you have but istead two rotating knobs for temp and vent control.
Wondering if my bulbs will be different. Anyone know?
Old 03-01-2011, 11:51 PM #6
GottaBeTRD's Avatar
GottaBeTRD's Avatar
the 3 buttons on top take 2 of the smaller bulbs and i think that your HVAC have 3 bulbs. (the bigger ones) i have the 3 knobs so its a little different but in reality having extra bulbs isn't a bad thing. you have some back ups
01 SR5 SPORT
Build Thread
Old 05-28-2011, 09:49 AM #7
ksroqclimber's Avatar
ksroqclimber ksroqclimber is offline
ksroqclimber is on a distinguished road
Added to Tutorial & Documentation Reference.
1997 4Runner - 4WD 3.4 V6 Limited - Anthracite Metalic
3rd Gen Tutorial and Doc Reference
ksroqclimber is offline   Reply With QuoteReply With Quote
Old 07-02-2011, 04:36 AM #8
Tucson4runner's Avatar
Tucson4runner Tucson4runner is offline
Tucson4runner will become famous soon enough
these bulbs can be bought at radioshack.....?
work in progress
Tucson4runner is offline   Reply With QuoteReply With Quote
Old 07-02-2011, 08:19 AM #9
SRSRunner's Avatar
SRSRunner SRSRunner is offline
SRSRunner is on a distinguished road
SRSRunner's Avatar
Can they? I had to go to the dealer when I did mine..
Great write up! I did that right after I bought mine, fairly easy to do, but this will help anyone who hasnt had to do it yet.
2000 Limited Deckplate/ISR mod Blue Wire mod, DRL delete. 12V mod, Fog Light mod. Taco/spacers, 8wraps.1"BL 285 Kumho KL71s
SRSRunner is offline   Reply With QuoteReply With Quote
Old 07-02-2011, 10:44 AM #10
SCRunner12's Avatar
SCRunner12 SCRunner12 is offline
Real Name: Robert
SCRunner12 will become famous soon enough
SCRunner12's Avatar
Real Name: Robert
I was wondering about getting new bulbs in. Anyone put anything other than the stock green? I was thinking of going with white if it works.
My 4runner Build Thread 2000 Limited 4runner SOLD
My Tundra Build Thread 2006 Double Cab Tundra SOLD
My Humpty Dumpty 4runner Build Thread 1999 Highlander 4runner
SCRunner12 is offline   Reply With QuoteReply With Quote
Old 07-06-2011, 03:08 AM #11
idk i was asking because i wanted to get blue if available but if they are only available at the stealer then i guess green will have to do
oh and fyi it appears that your runner is missing a door in your signature picture. just thought id give you a heads up if you hadnt noticed
work in progress
Old 07-06-2011, 09:46 AM #12
Qyota's Avatar
Qyota Qyota is offline
Qyota is on a distinguished road
Qyota's Avatar
I replaced mine with LEDs about a year ago. Now they barely work. They flicker on and off randomly. Not sure if that's a problem with the LED, or the connection at the PCB. Either way, I think I'll be replacing these with regular old bulbs soon (minus the green condoms).
Qyota is offline   Reply With QuoteReply With Quote
Old 07-06-2011, 12:16 PM #13
SRSRunner's Avatar
SRSRunner's Avatar
Lmao... as for the lights, Theres alot of people on here that have done led lights which I found out after the fact.. Where they got them I dont know. I didnt even think to look around for leds, My drive light was out at the time also so I just went to dealer and got bulbs for everything.
Old 07-06-2011, 01:50 PM #14
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
ALL MY BULBS ARE OUT@!
I guess that is what happens at 204k
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 07-06-2011, 09:02 PM #15
GottaBeTRD's Avatar
GottaBeTRD's Avatar
yeah there are dozens of threads on the LED swap (changing the color of your lights) I think autolumination,com sells the colored halogen bulbs just dont get their LEDs
If your LEDs are flickering it is a definite sign they are done for some good LED sites are SuperbrightLED's.com and VLEDS. i know quite a good bit on these just from doing them all the time so feel free to ask questions, Im not to familar with what years take what bulbs but i can prob tell what bulb it is with a picture
01 SR5 SPORT
Build Thread
FS: Alpine IVA-W205 Head Unit and BlackBird Navigation patricksheehy Classifieds - buy & sell (no commercial ads please) 6 09-12-2010 01:40 PM
Blue Dash bulbs for instrument panel alpine0000 4th Gen T4Rs 0 11-16-2005 12:48 PM
A/C Filter Rip Off KSinLA 4th Gen T4Rs 5 09-08-2004 12:27 PM
'04 A/C at highway speed ndgogal Problems & Warranty Issues 17 07-28-2004 01:12 PM
