Old 04-26-2015, 02:17 AM #76
jicko jicko is offline
jicko is on a distinguished road
Originally Posted by Wis4 View Post
How did you debadge the SR5 logo? Do you have a chrome exhaust tip?
You can/should actually delete the images.....
And you can also do "multiple quote", no need to respond one post at a time and quote every image & post.
How to debadge? Dental Floss.
I do not have the chrome tip.
Here is what Cooper Tires told me about my AT3's. Why wouldn't you go with what the door panel says...?
The tire may say 44 psi, that is the maximum amount of air pressure the tire can hold. That is not the correct tire pressure to run based on your vehicle weight. The correct pressure is listed on the driver's door of your vehicle, not on the sidewall of the tire. Please refer to your driver's door placard on your vehicle or vehicle manual for the recommended pressure. Proper air pressure is based on the weight of your vehicle and is determined by the vehicle manufacturer, not the brand or type of tire you have. Also, never exceed the max air pressure as listed on the sidewall of the tire. Most 2014 Toyota 4Runner models require 32 psi however, if you have TRD off-road package your air pressure is different and you will have to refer to the placard. "
The driver's door of your vehicle is based on P(essenger) tires. These are LT(Light Truck) tires. They go on completely different system. Do your research. If I am running Pxxxx tires, I will go with the door's listing. If I am running LTxxxx tires, I will go with what's the according/appropriate weight for LT tires to match with 32psi of P tires, which is 44psi. 44psi for LT tires is equivalent to 32psi of P tires.
I am looking at going with HID bulbs.
Why did you choose this vendor over this other one which is also listed all over? http://www.xenonsupply.com/toyota-4r...xenon-kit.html
Does the one you went with last longer because it's attached to the battery? What's the main difference?
How do the HID capsules perform in OEM reflector housings?
I ended up with XenonDepot, Philips 4300K bulbs. They are the OEM bulb for other vehicles which come with OEM HID lamps. Philips 4300K IS the industry OEM HID. I like that color (with about 100hrs of usage, it will be shifted to around 4700K). Only XenonDepot has that option (premium option, +$50), no one else do, not TRS, not XS, not many others. Everything else I had seen, screams aftermarket, most of the time, too "blue", IMO.
HID bulb in OEM reflector works, IMO. It's not any brighter than any other OEM HID vehicles.
I tried to sit in my "low" carrera, with the 4Runner (with HID in OEM projector) and my X5 (with OEM HID) side-by-side, they look virtually the same..... when I am head on with them or when they are behind me.
2015 SR5 Premium 4x4 / 3rd row seat
Jicko's Build & Adventure Thread
"Group buy, anyone?"
jicko is offline   Reply With QuoteReply With Quote
Old 04-27-2015, 06:50 AM #77
Why did you choose this vendor over this other one which is also listed all over? Toyota 4Runner HID Xenon Headlight Kit - Toyota 4Runner HID Lights
Why do you care, why are you even "looking at going with HID bulbs"? I thought you think those are all evil, illegal, babies-killing.....
Old 04-28-2015, 12:04 AM #78
Beyond Cargo Slide/Tray Installation
Life has been busy (with all those group buys.....)
Finally got a chance to install this "Beyond Cargo Slide".
I was really looking for something to mount my ARB fridge, and as I have the 3rd row seats (2015 SR5P) that I really need to use it a couple times a year, it makes any permanently installed cargo boxes, fridge trays etc.. a non-starter. This seems to be the ONLY solution for me as it can be easily remove (probably like 5-10 minutes).
So, it arrived nicely packed, and the product is surprisingly, very heavy, ~80lb! Very solid, nicely built, definitely.
The first step is to take 4 of the 6 straps, thread them thru the original factory tie downs, there are different ways and directions and twists for those straps, just try it out and find the best way for each.
Here is the back corner, passenger side:
After securing the slide with only the 4 straps, there is still a little "play", probably due the fact that the 3rd row seats locking mechanism has a little play. It is probably fine, but it is not as "solid" as I'd like. And I do plan on putting some weight on this slide.
So, I use the 2 remaining straps, and fish them thru from behind to the 2nd row seats' child-seat LATCH anchors (middle 2), and hook them to the rear cross member of the lower frame of the slide. Wa-la, that makes a night and day different!
2nd row left most seat, right behind the driver. The right LATCH:
I slide the 2nd row seats forward to make that fishing exercise easier, and then slide and lock them rearward and hook the strap hook to the rear cross member.
Both the 5th and 6th straps are in place:
The 4 straps at the back holds the slide in place solidly.
I can totally sit on it and it is not going anywhere! (Ok, I am nowhere near the 250lb limit.... but you get the idea)
We still have a few left in our group order, if you are interested, you can still get it via this thread: http://www.toyota-4runner.org/sale-t...2A-2015-a.html
Old 04-28-2015, 12:16 AM #79
Magnetic4R Magnetic4R is offline
Magnetic4R will become famous soon enough
I need to stay away and resist. lol. every time i get on and see this, I'm so tempted. haha. Must resist. Nice to have, but no concrete plan for use yet. Wanted something for my photo gears though.
'14 4Runner Limited Redwood: Suntek films, AVS visors, BAMF Sliders, WT Liners, 35% tint, TE37 18x9, 285/65 RidgeGrappler, Spidertraxx, Gobi Rack, Bilsteins 6112/5160, ICON Overland, CVT Mt. Shasta, TRD skid, RCI aluminum skids, BW flares, TC UCAs
'14 RX350 F-Sport: '02 GS430: '92 Integra GS
'14 S-Work Enduro: '13 Canfield Yelli Screamy
Magnetic4R is offline   Reply With QuoteReply With Quote
Old 04-29-2015, 01:07 PM #80
I pulled the trigger on the Toyota (Southeast) P/N:00016-48011 "LED Fog Light & DRL 2in1", its not cheap, but it is really the best solution I had seen (a Fog light that is color matched to my 4300K HID). I also dig the fact that it is also a LED DRL.
2015 TOYOTA SET HIGHLANDER 4 RUNNER LED DTRL FOG LIGHT COMBO 00016-48011
Installation Instructions (relatively plug and play):
https://cdn.shopify.com/s/files/1/01..._mcdonough.pdf
Old 04-29-2015, 04:08 PM #81
Saker's Avatar
Saker Saker is offline
Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of
Saker's Avatar
@jicko
Ok, does this delete the OEM DRL at all, or do you have to do the Disable DRL Mod?
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Saker’s Ebony Build | Saker’s Previous 2014 Midnight Build | Scuba Mod| Scuba Mod w/ Locker | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 04-29-2015, 05:42 PM #82
Originally Posted by Saker View Post
@jicko
Don't know yet, I will report back later!
Old 05-03-2015, 12:18 AM #83
reece04 reece04 is offline
reece04 is on a distinguished road
At Discount Tires now.....
Have jumped thru LOTS of HOOPS to get here....
Last look of the SR5 wheels and stock tires:
Unboxing of pure beauty:
Their "sole mates" are waiting:
And I'm sitting right here waiting too......
How are you liking these wheels and tires? I had the same setup done a few months ago with TRD wheels and KO2 275 tires... Discount put 40psi and it felt a little sloppy on corners. This past weekend I had them run up the back to 50 and the front to 45, I am much happier with how it rides, even on washboard roads.
2014 4runner - Toytech Boss lift, 275/70R17 BFG KO2s on TRD Wheels.
1990 GMC Suburban 4in lift 33x12.5R15 BFG KOs
reece04 is offline   Reply With QuoteReply With Quote
Old 05-03-2015, 03:58 PM #84
I have them all @ 44psi, I like that a lot. Maybe I will try to play with different pressure if they indeed make a difference.
44psi on these LT tires is equivalent to 32psi on the original P tires.
Why do you run them differently in pressure, front and back?
Old 05-06-2015, 11:54 PM #85
I only did the higher pressure in the back because that day I was towing a heavier trailer (3500lbs) I did not want to squish my tires I have since lowered them to 45 all the way around. and I am happy.... At 40 I could hear/feel them flexing on corners
Old 06-06-2015, 12:07 AM #86
Look! What came in today!
Brand NEW, authentic Scepter NATO MFC / Military Fuel Cans and MWC / Military Water Can!
These are the BEST fuel cans that money can buy!! (yes, they are pricy & difficult to get in the US)
I did find some on Amazon (these are Scepter's):
Scepter Military Fuel Can
I do prefers Scepter's, but LCI's ones work too for the water can:
Scepter Water Can
LCI Water Can
Get this spout if you have one of these water can, it is a pleasure to use:
Scepter Water Can Spout
* Do NOT confuse these with "civilian" version which have a much smaller "cap"; my experience is only with these "military" version that has the big cap. I don't think the "civilian" small cap version works too well.
** I'll do a more detailed review on these soon!
Jicko Build Thread ...-10409410_10153485330286980_86831853259669094_n-jpg  Jicko Build Thread ...-10406758_10153485330241980_6117400844702756999_n-jpg
Old 06-06-2015, 12:18 AM #87
DLH87 DLH87 is offline
Real Name: David
DLH87 is on a distinguished road
Real Name: David
Brand NEW, authentic Scepter NATO MFC/Military Fuel Cans and MWC/Military Water Can!
Thought I was going through deja vu. Saw this over on a Facebook group as well. Very nice!
2015 Magnetic Gray SR5
2008 Black SR5
DLH87 is offline   Reply With QuoteReply With Quote
Old 06-06-2015, 09:51 AM #88
Mooney's Avatar
Mooney Mooney is offline
Mooney is on a distinguished road
Mooney's Avatar
Group buy?
2014 TEPP (Trail Edition Premium Pro), ICON S5 2.5, Remote Resi,w/CDC (Compression Damping Control), ICON Billet UCA's, Nitto Terra Graps, 285's, FN Five Star 17x8.5, SSSlimline Hybrid Bumper, Warn Zeon Platinum 10-S, Factor 55 Pro Link, Factor 55 Hawse 1.5 inch Fairlead, Metaltech OPOR Rock Sliders, KDSS, Sunroof, TRD Shifter & Engine Bling, Carbon Fiber Trim
1994 Limited, 257k Miles, 3.0
Mooney is offline   Reply With QuoteReply With Quote
Old 06-06-2015, 10:13 AM #89
Originally Posted by Mooney View Post
Group buy?
Explored that, no can't do. :-(
The only place I found that have them in US is way too expensive, and the place I got then from in Canada, cannot/will not ship fuel containers across the border. I ended up arranging someone to physically go there, pick them up, and fly them here to me as their luggage.
Some other ones that I found here in US either are used, or has the "US property" or "For Military Only" markings on, or are not made by Scepter (even tho they look very similiarly).
I think the only ones that will seal perfectly tho (no venting, breathing, and with Viton gasket that will not degrade by gasoline), are the true Scepter NATO version.
Also, I think, since there is no breathing or venting in these Scepter NATO cans, the gas will not become gummy, hence no addictive is needed for long term gas storage (I am STILL researching and confirming on this).
Old 06-06-2015, 10:17 AM #90
reidbailey's Avatar
reidbailey reidbailey is offline
Real Name: Reid
reidbailey is on a distinguished road
reidbailey's Avatar
Real Name: Reid
You're a group buy philanthropist! Thanks for thinking of us even though it wasn't realistic.
2011 SR5 - Trail hood - Method NV wheels, 285,70-17 Duratracs - Toytec Boss lift - Shrockworks dimple sliders/trail trim/battery, ACR & Switch mounts/skids - Weathertech mats - LED bulbs - 18% tint - Gobi Stealth, cargo slider, ARB dual twin compressor with 1.5 gal tank, Retrofit head lights (MORIMOTO FX-R Stage III, XB 55, DS2 XB 5500k, XB LED Fogs, DDM LED high beams) Bussman box, Switchpros, Bluesea ACR, Odyssey second battery.
(Have but need to install: Seat heaters)
reidbailey is offline   Reply With QuoteReply With Quote
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
wyanrard's 2003 SR5 V6 build thread/picture thread wyanrard 4th Gen T4Rs 56 02-04-2017 01:03 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
