Originally Posted by Stuck CAPS
To address the air duct being intruded, could you not intall it on he duct, and fit the cover over it, then close it? that way, you could seal it using, say, automotive grade silicon, and there would be no AC leak... Air would actually come out a bit faster, too.
You could probably do that but it would be tricky getting the outside hole drilled exactly right and if the hole gets dinged up, the mounting ring wouldn't cover it. It'd be really easy to make it look bad instead of close to factory.
2004 4Runner SR5 SR5 - V6, 4X4, Moonroof , JBL, Leather, Stratosphere Mica
Installed Mods:
Spoiler,
HIR bulbs,
Kenwood DNX6960 Nav,
Back Window Up with Remote Mod, Rear Camera, LED Tails,
Key Reminder Disable, OEM Automatic Headlights,
Rear USB Ports,
Seat Heaters,
Aftermarket Third Row,
Heated Side View Mirror
Locations: VA
