Originally Posted by 541joseph
Multi mode cases aren't j shifts they are push button awd and have push button 4wd and the shifter is for h and l
This is incorrect J shift is multi mode just a different flavor of it.
Originally Posted by 4-Ripcord
-In ’99-’00, the limited upgraded from a standard transfer case with push button, over to a differential type transfer case (known as Multi-Mode). This type of transfer case still has a push button to engage 4wd from 2wd. A differential type t-case is different from a standard t-case in that the front and rear drive shafts could rotate independent of each other and avoid binding on high traction surfaces. Until this center differential was locked, the vehicle is essentially in all wheel drive (discussed more below).
To lock the T-case, you simply shift from 4Hi to 4Hi(L).
-In 2001 and 2002, all models gained these Multi-Mode transfer cases (including limited, now they all have the same system). But, the locking method changed from a separate shifting position to a separate push button on the dash.
T-case Differences (all years of 3rd gens).. transfer case, AWD, multi-mode
I HIGHLY encourage you to read this thread skillfully written by Brian2sun. It is more in depth and contains information such as recommended speeds, shifting configurations, Pictures, Uses, and more differences.
The information above is a summary of the information in his thread.
