Originally Posted by kishanSR5
I took a look at your exhaust setup and it looks really good! It also cleared up a lot of things. So yes the cat that I deleted is the upstream cat. I left the downstream alone alone and the O2 sensor which is past the downstream cat alone as well.
The bung that I have on my headers is for the A/F sensor. I may get a bung welded into the pipe replacing the upstream cat for a wideband sensor, but thats later on.
I believe my cat is fine, and I may eventually replace it with a high flow cat, but I do believe that my only option for clearing the code for good is getting that URD attachment.
Thanks for all the help!
No problem. I'd be curious to know what actually fixes it. Instead of the URD sensor simulator you can order a new O2 sensor (Denso) and see if it clears. As most have said that's usually the culprit. Good luck.
2001 Imperial Jade Gold Letter Sport Package - Original Owner
