View Single Post
Old 10-11-2008, 04:47 PM
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
Re: Now WTF do I do? Diff change doh!
Originally posted by quadzillabill
Doing front and rear diffs and transfer case fluid changes today. Rear had extra tight fittings, but otherwise no problem. Transfer case was a piece of cake. I decide to tackle the front last and after getting the rear skid plate off I found the offending fittings. Pretty rusty looking, I cranked on the fill first to make sure I could get it loose. Took some tapping and a small helper bar, but it came out. The drain is lower and had more rust around it than the fill and proved to be more than me or a helper bar could handle.
I took my 10mm hex key and put it on the end of my 3/8" drive air hammer to see if I could break it loose. After several cycles of lefty-loosey and a right-tighty shot or two hoping to break it free, the drive key got stuck and then after pulling out out I stripped the drain plug.
Now what do I do?
I really do need to change that front fluid as from the looks of everything its the original install of fluid and I'm just rolling up to 100k miles. Looks like I'm going to end up at a shop on some kind of lift where we can try to get at the plug with some specialized tools or extractor. Its going to be a pain in the arse from what I can see.
Do I need to reinstall the rear skid plate if I'm only driving on the road for a very limited amount until I can get that done - or better to put it back on just in case?
I hate it when straightforward jobs go bad.
I am not slamming you but this is another reason why I never go more than 3-4 years or 45-50k:soapbox: Another trick is to always loosen the fill plug prior to draining an axle or t-case.
Ideally you DO need to change it. For a short, on-road jaunt I wouldn't worry about the skid.
If you want take a piece of cheap, clear hardware store hose and 'suck-out' the front axle. It's not ideal but it would buy you a little time to strategize about getting the plug out and order a replacement.
Good luck! That's a PIA, I hate it for you...
CJ3Flyr is offline   Reply With QuoteReply With Quote
