Originally Posted by himeeto69
I have a 2005 SR5 4WD I just bought. I have 3-4 lights on. The VSC, TSC, check engine and wheel flat sensor thing (not sure what it's called and not sure if the lights are connected in any way) Does anyone have a fix or a link to a thread with a fix?
CEL means you have a code stored, you need to scan with a code reader. VSC and TRAC will come on if you have the CEL, since the computer knows it can't really trust itself to make VSC/TRAC decisions if theres something else wrong.
The flat wheel is TPMS: Solid means low pressure, flashing means bad sensor or sensor communication. You can replace the valve stems with the TPMS stems for like $40 a piece from RockAuto. Another option would be to just delete the system and check tire pressures regularly. There is a thread for the TPMS delete, you'll have to search for it
