Originally Posted by Perfection
Howdy folks. Reviving this thread with same problem, new twist.
2012 Trail Edition. So my driver's side brake light won't light up, center and right work fine. Both filaments are fine in the bulb, and the socket isn't the problem.
The problem is the blue wire feeding into the grey wiring harness that plugs into the taillight housing. I can wiggle it, and at times the brake light comes on, but I cannot get it fixed/working consistently. Can I purchase this specific harness from Toyota or elsewhere? Is there a part number or way to find it? Or do I have to pay the stealership to fix?
Thanks in advance!
Glad to see another 2012 TE! I haven't had that problem but i know what you are talking about. I have worked on wiring harnesses before and I would bet that you can fix it with some patience and research on how to undo the harness without breaking it. I say go for it yourself. If you fail and don't have time to keep trying, then I would bite the bullet and go to the dealer, assuming it's one that you trust.
