Originally Posted by andreylights
Can someone share the symptoms of the issues?
I have recently noticed that Freon is leaking (the ac is not as cold), it has been recharged and now it seems to slowly leak again. On top of that there is a difference in temperature between passenger and driver vents. Does that match the subject's description?
With AC on, passenger cold and driver warm usually means low on freon, but there are a few other things that would cause this like the blend doors actuators and another reason that seems to be escaping me right now. I just remember someone had this issue and something strange fixed it, kicking myself I can't remember what it was.
Dye leaking into the A/C drain is one of the big givaways. I have extended my AC drain with clear vinyl tubing, and it was bright green after like 3 days. That is what the picture I have linked above is showing.
