Tundra Strut
OHP
The answer to this question is probably in here somewhere but there are so many threads on this topic, it's easier to just ask than spend hours reading.
Is the whole tundra strut assembly a direct swap or will only the spring mounted on our struts work?
Thanks
The only thing you need from the stock strut is the top hat. The tundras bolts are too big to fit through the housing, so you need to switch them. Other than that, it's a direct replacement.
