Airlift 1000 bags rubbing?
wardriver
I installed a set of airlift 1000 bags last last week. I was driving it around and at certain low speeds I could hear metal on rubber rubbing. I confirmed it was coming from the driver side rear bag. Plenty of air, I reduced the air a bit more to see if that would help and it did not.
So I'm wondering if anyone else has had this issue and should I be worried?
Thanks
Keep the shiny side up.
WD
Thanks
WD
Interested in hearing feedback on this as well as i've got a set sitting about 18 hrs away from my front porch at the moment and planned on trying to get them put in this coming weekend. How'd the install go? Any tips/tricks, follow instructions, etc...?
Do a search for install methods. I did not disconnect the sway and pull the springs out. You can compress the bags and squeeze into the coils. It wasn't too bad, just tough to shave/expand the hole that way, but I recommend that route. No issues with mine at all. The only time I hear one of them at 5psi is pulling into or out of my driveway with the big bump needed to get in.
You wont be disappointed.
- Sent via Tapatalk for Android
Did mine the same way - didn't take anything off but the wheels. A sharp knife will work on the bump stops.
WD
So I feel like a total dork - and I'm glad I had the bags on there to squeak....because I neglected to fully tighten the lug nuts on that wheel.
Curious if these would fix my bouncy rear end. Oh, that did not sound good at all. I have the stiffest OME rear springs (at least that is what the previous owner told me) With my rear cbi bumper w/swingout the rear compresses way to easy.
Did you install the ones the website specifys (Item# 60743 ) or another?
thanks
The PO had the coil replacement done by the dealer 2 years ago. They were compressed badly already. I didn't want a huge lift from the LC springs and I wanted it to be level when I pulled my popup camper. After I would fill my gas tank I could not get my finger between the bumpstop and the axle. I'm super impressed with these so far. They ride great. I did install the ones prescribed by the manufacturer. For what its worth I got them cheaper than list from AdvanceAuto.com. Got to RetailMeNot: Coupon Codes, Coupons, Promo Codes, Free Shipping and Discounts for Thousands of Stores to find a discount code. I got a $50 off $150 code and picked up some other parts I needed. Much better than paying the $110 retail price.
Here is a shot of the bag with the bumpstop. I'll snap one later when I hook up the camper.
PhotoApr04125600PM.jpg~original
I did one less than the manual said - so I think I took the bottom 3 off. Love how it sits now.
Cool. I've already swapped my 01' coils for some 99's (thanks ryan :thumb3:) last year so I figure the best thing for me to do is just do some measuring and cut from there. Got underneath tonight afterwork and mapped out how I want to run the hoses and how I envision everything going. Hoping I can knock it out a few hours, taking my time, and making sure everything's tidy'd up the way I want it.
Decided i'm probably going to go ahead and cut a 1" hole into the floor of the rear cargo area (by the back tie down located near the liftgate), and head over to Lowes/HD and pick up some sort of grommet that I can run the tubes up through from below and hopefully find some sort of "cover piece" that I can just screw down, leaving the (2) nozzles exposed, easily accessible for air in/air out, yet keep them out of the elements. Shouldn't even really notice them hanging out over tucked away in the corner (thats my hope anyway). Picked up a descent inexpensive 12 volt air compressor also from amazon whe I ordered the bags, figure I could mount that over there near that area as well. Plug right into the 12v outlet in the back when doing my adjustments.
EDIT: Was just thinking about what sort of "cover piece" screwed to the floor would work best, and something like these switch plates (in black or even stainless I guess) might work perfect.
renderImage.image
EDIT II: Wardriver, with our setup and "long" bump stops, you never even use the pucks/spacers that come with the bags, do you?
thanks
Hey Josh, here's a link I found for a thread over at T120 back when I was just starting to look into these. It might be more your style as its a guy dealing with aftermarket (non OE) coils.
airlift 1000 - Toyota 120 Platforms Forum
Just got my Airlift 1000's in today. A few notes:
1. Can do the install w/o taking coils off, but easier if you jack it up some get those coils expanded.
2. Forget a razor knife of any kind, to thing to do the job. I went at it with a coping saw, probably a med blade (#of teeth) and flipped the blade around so the teeth were going away from me. This gave me plenty of "biting" with the blade, and with the coping saw I was able to manipulate the angle of the saw to get in some really tight spots while hacking off the long bump stop.
3. Speaking of hacking off the bump stop, can't just hack off the 3rd one up and go on your way (LOL, it falls down and the coil and your stuck). Figured that out on the 1st side, and then played hell trying to chop up the bump stop while its rolling around inside the coil :(
4. When "squeezing" the bags into the coils, I found it easiest to go about 1/2 way up the coil, and squeeze the bottom (nippled side) in and then force the rest of the bag in and down (can get more leverage this way obviously, in some very tight spots, by pushing down instead of trying pull the top up).
I'll take some pics of how I'm going to finish everything in the rear cargo area as right now its just "hanging" around. I'm still going to use the switch plate cover idea (and its working well right now), but I need to get a box to screw the plate in instead of mounting it to the floor as I originally intended to do.
I'll keep adding some more notes as I think of them. And BTW, they do give about a nice 1" lift (running just below 30lbs), and do have a nice kind of "airy" feel with regards to bumps. I do still plan on tweaking the psi, and I still have to get my spare on which is going to add some weight to the equation, so we'll see what happens then. So far though, really happy with the purchase, and overall install wasn't to bad except for a few "doh" moments.
EDIT: Added a pic of what I finally decided to with in the rear cargo area. Metal electrical box/plate painted with some left over silver wheel spray paint I had laying around. Also went around the tubing indicated in the underneath pic with some krinkle flex tubing and cleaned that up a little more. currently running 30 psi on the drivers side and 25 psi on the passenger.
Yea - forgot to mention that. I too failed to star with the bottom stop....
Good call on the coping saw though.
As promised - from our trip this weekend. Pulled it 600 miles with no issues. Before the airbags my headlight would have been pointing at the trees and not the road. Also - the rear cargo of my truck is absolutely full.
PhotoApr0861641PM.jpg~original
