work in progress
Great looking Runner! Get some more pics up when you get a chance.
And I stopped watching your vids. Made me already dread that it's fall.
Cut the running boards off and got my roof rack on today
Piecing Together a Lift
I have some 9.25 wraps currently being shipped, I'm not sure what I'll be using for shocks yet. Given what other people have said these coils provide alot of lift so I'm interested to see how it turns out. For the front I'm debating on tundra/bilstein's or just saving for toytec coilovers....
Here are the LC 9.25 wraps, I ordered them from cruiserparts for $45 each.
Your 4runner looks great!
What perch do you have the 5100's at? Did you take any hight measurements?
Looks good.
Lookin good sir! Those 9 wraps are super flex, I love mine.
Thanks! yes they are veeeeery flexy I cant wait to hit some trails with the new setup.
Thanks Yoter, the 5100's are set on the third perch up. I took some measurements but I don't think I did it correctly (23 1/2 in the front and 25 1/4 in the rear) Ill have to go out and take them again.
I had a question with regard to ball joints. I noticed on two occassions a big "clunk" noise on the front passenger side while at full lock, both times when reversing, while turning around doing a 3-point turn. So this morning I thought I should try and diagnose it. I wasn't able to get it to make the clunk again, but while inspecting other areas I noticed this
IMG-20130401-00547 by BryanHynes, on Flickr
They look pretty brutal I wouldn't be surprised if they are the original ball joints. The grease coming out of this one doesn't suggest they like the new lift as much as I do. I wont have time to do ball joints until later in April when school is finished. Is the 4runner still safe to drive?
more pics
IMG-20130401-00546 by BryanHynes, on Flickr
IMG-20130401-00544 by BryanHynes, on Flickr
IMG-20130401-00543 by BryanHynes, on Flickr
EDIT: I think I sort of answered my own question I'm just gonna let the 4runner sit until I can get the ball joints done. 200 bucks vs damage caused by lbj failure.....I guess it is pretty obvious
the clunk is your steering stoppers, they are supposed to have rubber stops on the metal bumps but have worn off. mine does the same thing. right at full lock or when pulling into a parking spot there is a clunk that is pretty loud when parking. maybe someone else can point out where they are at.
ps it doesn't do it when you are standing still and turning the wheel. only when moving as well.
As far as ball joints go, I replaced all four of mine after my lift. Along with tie rod ends and CVs. Everything was original and I replaced for safety. I use the old CVs and LBJs for trail spares.
thanks for clearing that up [MENTION=14772]shootmymime[/MENTION]. I think I will do the same [MENTION=54101]AZTOY[/MENTION]
what are you using for the frame?
also it looks so good! keep up more pictures! i want to see more when you are finished with the axles and everything! but dang it looks good!
Trdoffroad916
