P0305 - #5 misfires when started warm....
Chugger
I'm new to the forum. I just bought a 1999 4Runner. Its a 3.4l 155k miles and is nice. I'm told that the engine was replaced for a factory issue around 40k miles. Love it!!!
It has a known issue... The engine misfires when started while warm or recently run up to temp.
Once it gets warm the #5 cylinder dies upon restart and the only code kicking out is a P0305 (thanks to the great folks at Woodbury Auto Zone who read my codes for me!!!) . After reading the forums on this issue this is what I've determined. I'd like to fact chack myself before going down the wrong road, or rabbit hole!!!
Spark is coming from the wire to the plug, so it's not the coil. It could be a wire, but that would be less suspect because it does not happen when cold, it is never ever intermittent, it either runs 100% or #5 dies. So it's probably not the wire.
I read that the injector has a relay inside of it. That could be effected by heat and is the odds on favorite to the problem. Has anyone else seen this?
My plan was to carefully tear down the top. and replace the plugs, wires and the #5 injector. It's probably ready for plugs so I figure why not. I could move the injector to another cylinder, but the time involved, is it worth it because I'm probably going to find the injector bad anyway?
Also, speaking of Auto Zone, there are two injectors for this engine availaible. One is $175 and the other one is $40. I've read where folks have used $40 injectors and things worked. But... Are these things any good? Such a disparity in pricing makes me are the rebuilts worth it or will I regret it? Money is an issue, but I don't want to be stupid.
I also noticed that the valve cover was leaking. So I was going to replace the valve cover gaskets and really clean things up. How much more work is it to do the covers once your've got everthing else apart?
Are are there any other "maintenance items" worth replacing while I'm in there? I'd rather not have to do this twice.
Thanks
Here are some part#s I plan on involving when I switch mine out in a few weeks. There's also a write up on the yota site.
11213-62020 GASKET, CYLINDER HEAD 2 $28.01
90210-05007 WASHER, SEAL 16 $1.21
17176-62040 GASKET, AIR SURGE TANK TO INTAKE MANIFOLD 2 $14.18
90430-37140 GASKET (For oil filler cap) 1 $2.58
11188-62010 PLUG, CAMSHAFT HOUSING 2 $12.20
11193-70010 GASKET, SPARK PLUG TUBE 6 $3.90
90480-18001 GROMMET (For PCV) 1 $5.06
17176-62040 Intake (air plenum) gaskets 8.54 x2
22271-62040 Throttle body gasket 3.51
90301-07024 O rings for each injector 2.29 x12
90480-13005 Grommet for Injector 2.56 x6
90210-05007 Valve cover bolt gasket 0.73 x16
11213-62020 Valve cover gaskets 18.56 x2
17177-62060 x2 Intake manifold gasket
Wow...
I do appreciate the information! The parts list is so helpful and the link pretty much lays out everything step by step, making it look easy.
Tomorrow night I plan to tinker with it and move the faulty imjector to another position and confirm that the code follows.
I have same exact problem with P0302...
i had the same issue at similar miles....my bet is on faulty injector. good luck keep us updated
Having the same problem with a P0302 code...what was your fix twa318? I replaced plugs, wires, coils, couple of cracked vacuum hoses and removed all of the injectors and sent them to Witchhunter performance. Witchhunter cleaned and tested after replacing orings etc and they all tested fine. Put it all back together after cleaning throttle body and MAF and exact same problem still there. Plan on taking to a local shop to troubleshoot on Monday as I can't keep throwing money at it and I can't figure it out...
http://www.toyota-4runner.org/3rd-gen-t4rs/138866-rough-idle-check-engine-light.html
Sorry just seeing this now. My injector #5 was faulty and replacing it solved the issue
