Old 02-13-2015, 01:06 PM #16
BassnmanMike BassnmanMike is offline
BassnmanMike is on a distinguished road
Originally Posted by MONTYMTB View Post
I took mine off and painted them black. Really not too bad a job - unless you break them that is
The window switch trim (switches are easy to remove), gear surround and the part you're talking about are easier than the instrument cluster and ignition surround, but none of it is that difficult.
@MONTYMTB , you mentioned the window switch trim is easy to remove. Are there just clips under them so they just pop out?
BassnmanMike is offline   Reply With QuoteReply With Quote
Old 02-13-2015, 01:34 PM #17
Never mind, I found this.https://www.youtube.com/watch?v=7hRQjM9VzZQ
Old 02-13-2015, 01:41 PM #18
MONTYMTB's Avatar
MONTYMTB MONTYMTB is offline
Real Name: Monty
MONTYMTB is on a distinguished road
MONTYMTB's Avatar
Real Name: Monty
Yep. Just use a flathead and pry the front part up to release the clip:
Then slide it forward and pull it up and out:
There are 4 connectors you will need to unplug, and once you get the unit out it's easy to see how the switches come out. As you can see, the black paint on mine is chipping away - my fault because I didn't take the time to prep it properly before painting.
'99 Limited 4WD, V6, Auto
MONTYMTB is offline   Reply With QuoteReply With Quote
Old 02-13-2015, 01:46 PM #19
Thanks
Old 02-15-2015, 08:53 PM #20
RadoShred RadoShred is offline
RadoShred is on a distinguished road
Thanks, let me see if I can find a black one, if not then I'll buy yours and paint it black.
I have a black one I could get you soon if you're not in a rush. I have a ton of work I'm trying to do in swapping trannys and fixing some exterior damage first.
If you're interested.
RadoShred is offline   Reply With QuoteReply With Quote
Old 02-16-2015, 12:47 PM #21
Thanks for the offer, I found a set at my local salvage yard
Old 12-09-2019, 09:45 AM #22
outatime4runner outatime4runner is offline
outatime4runner is on a distinguished road
Anyone selling one? I cracked mine swapping out stereos.
About to pull the trigger on 1999-2002 Toyota 4Runner Center Panel 55412-35200 | DiscMonster but figured I would check here first.
Would post in classifieds but I think I need 20 posts or something before I can start a new thread.
Thanks!
Edit:
I have a 2001 Toyota 4Runner Limited 4WD. Looking for one that is a match to existing wood grain.
outatime4runner is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 03:26 PM #23
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
Thanks!
Edit:
I'd suggest a junk yard. I found a replacement for mine for $20 when I broke it
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 09:26 PM #24
BikeIdiot BikeIdiot is offline
BikeIdiot is on a distinguished road
I noticed some have painted and others plasti dipped. Any feedback on durability for each?
BikeIdiot is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 10:25 AM #25
Real Name: Daniel
Real Name: Daniel
Well people usually use plastidip as a temp 'mockup' before real painting so they can see if they like the color without committing.
If you know the color you're gonna stick with, I'd suggest paint and be done with it. It's cheaper than plastidip, too.
Old 12-10-2019, 10:42 AM #26
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Some people peel the wood off the panels to expose the black plastic underneath. Seems like a real pain though.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 06:07 PM #27
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have no idea why anyone thought stick on woodgrain was a good idea. I have a 98 limited with that originally in it. And my parts mobile was a limited without stick on woodgrain. Must have been some kind of addon dealers did as I hope that wasnt stuck on from the factory like that. Being the age of it now. No way would it survive being moved around too much.
8 3rd gens listed in the build thread (2 are parts mobiles)
Previous Rigs: 90, 91 Camry 82,83, 87 Hilux Pickup
LED Dash Question zacattack20 3rd gen T4Rs 6 10-26-2014 10:46 AM
Dash / mounting kit question Aviationtech Engines / Suspension / Wheels / Tires / Audio / Accessories 6 01-06-2014 12:06 AM
DVD dash kit question SC Joe 4th Gen T4Rs 24 09-22-2011 05:53 PM
Dash removal Question?! ameining 3rd gen T4Rs 6 07-30-2011 08:47 PM
87 dash pad question Tack427 Classic T4Rs 2 02-04-2005 05:22 PM
