Old 07-31-2020, 11:10 PM #1
OpenYota's Avatar
OpenYota OpenYota is offline
Real Name: Chris
OpenYota is on a distinguished road
OpenYota's Avatar
Real Name: Chris
Need help finding PN for exhaust gasket, studs/bolts and nuts
So I have a nice leak coming from my bad gasket in the flange where the catalytic convertor meets the exhaust pipe and I need some help finding part numbers for the gasket itself and the studs/bolts & nuts.
I believe the PN for the gasket is 17451 but when I pull it up online there are two that fit my vehicle but are different prices so I'm not sure which to purchase.
Any help would be appreciated.
I'm running a 2001 4runner SR5 4x4
Exhaust leak - Album on Imgur
2001 SR5 4WD
OpenYota is offline   Reply With QuoteReply With Quote
Old 08-01-2020, 04:15 AM #2
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
I got some from napa and took my old gasket for reference. You can also get them at advance auto and autozone.
As for the bolts......any grade 8 fine thread bolt that fits the hole will be fine. Just get flange head. My local ACE has all that stuff. And if not MSC is 35 min from me.
Old 08-01-2020, 06:45 AM #3
Pj Benn Pj Benn is offline
Pj Benn is on a distinguished road
Looks like you got the exhaust with 2 cats.
90917-06057 Gasket for photo
90105-10388 Bolt
90179-10133 Nut
Parts catalog for Toyota 4Runner
Pj Benn is offline   Reply With QuoteReply With Quote
Old 08-01-2020, 09:14 AM #4
OpenYota's Avatar
Real Name: Chris
OpenYota's Avatar
Real Name: Chris
90105-10388 Bolt
90179-10133 Nut
https://dz310nzuyimx0.cloudfront.net...285634e733.png
So that is the diagram for where that gasket goes, in the diagram it is in position 9 but the one I need is in position 11. Are they the same gasket?
Also, the bolt doesn't fit my vehicle when I check for fitment on McGeorge Toyota's website
2001 SR5 4WD
Old 08-01-2020, 01:25 PM #5
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
90917-06072 No 2
Bookmark this site
TOYOTA 4RUNNERVZN185L-GKPGKA - TOOL-ENGINE-FUEL - EXHAUST PIPE | Japan Parts EU
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 08-01-2020, 01:57 PM #6
Is that diagram from a Tacoma?
Old 08-02-2020, 09:14 AM #7
OpenYota's Avatar
Real Name: Chris
OpenYota's Avatar
Real Name: Chris
I'm not sure, it was the diagram that was shown when I submitted my vehicle spec to check if the part had correct fitment.
17451(no.1) is the part number that I need but multiple of the same part number will show on parts websites and I'm not sure which is the correct one.
2001 SR5 4WD
Old 08-02-2020, 10:44 AM #8
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
this is a 2001 VIN I pulled off ebay
this site has a very easy to use interface, you should be able to pull the part numbers you need from here.
EXHAUST PIPE | 4RUNNER VZN185L-GKPGKA RZN18#,VZN18# | JT3HN86RX10353568 | Toyota | Genuine Parts Catalogs | PartSouq Auto Parts Around the World
there are 2 different parts for that one...and I can't remember the one I used.
one is $3 and the other is $5 so maybe just get both and your good? if your going to fix this youself? I would also get the bolts/nuts for that connection?
Old 08-02-2020, 11:54 AM #9
17451 is not the part number, it’s an item code or something. I am confident that the one you need is the part number I posted earlier but at this point I agree with sleepydad, it’s really cheap just buy both since you’re worried
Old 08-12-2020, 11:04 AM #10
OpenYota's Avatar
Real Name: Chris
OpenYota's Avatar
Real Name: Chris
90105-10388 Bolt
90179-10133 Nut
These ended up being all of the correct part numbers that I needed.
Thank you so much for your help!
2001 SR5 4WD
Old 08-13-2020, 01:46 AM #11
MagusWyatt's Avatar
MagusWyatt MagusWyatt is offline
MagusWyatt will become famous soon enough
MagusWyatt's Avatar
Originally Posted by JRZEE2000TR4LTD View Post
I found this link in an older thread a few months ago. I can't remember what thread it was in or I'd go back and thank the guy for one of the best links I've ever seen. Never again have I had to ask for part numbers!
EDIT: I just realized that I could search the site for "Japan Parts EU" to find that thread. Lo and behold, IT WAS YOU! Hahaha. Thanks for the link!
1998 SR5
MagusWyatt is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 09:27 AM #12
96RedRunner's Avatar
96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold
Originally Posted by MagusWyatt View Post
I found this link Never again have I had to ask for part numbers!
"Japan Parts EU"!
Been using that site 4+ yr now, find "your" part number, assembly drawings good reference also, at times better than FSM.
Edit: If more people used link Part # threads would disappear, maybe !!
exhaust , finding , gasket , nuts , studs/bolts
WTB: 3RD GEN Studs, washers, & nuts billmilner Want to Buy/Trade 1 01-25-2020 04:28 PM
Finding studs behind drywall and plywood bofa Off Topic 24 11-10-2018 11:56 AM
where do the TWO STUDS in the oil pan bolts go? gtgt_bangbang Classic T4Rs 3 01-31-2015 10:32 AM
Exhaust system gasket - bolts - studs - nuts radlynx 4th Gen T4Rs 0 10-10-2012 11:43 AM
Lug Nuts/Studs spencersausser 3rd gen T4Rs 3 10-24-2011 11:54 AM
