Need help finding PN for exhaust gasket, studs/bolts and nuts
OpenYota
So I have a nice leak coming from my bad gasket in the flange where the catalytic convertor meets the exhaust pipe and I need some help finding part numbers for the gasket itself and the studs/bolts & nuts.
I believe the PN for the gasket is 17451 but when I pull it up online there are two that fit my vehicle but are different prices so I'm not sure which to purchase.
Any help would be appreciated.
I'm running a 2001 4runner SR5 4x4
Exhaust leak - Album on Imgur
I got some from napa and took my old gasket for reference. You can also get them at advance auto and autozone.
As for the bolts......any grade 8 fine thread bolt that fits the hole will be fine. Just get flange head. My local ACE has all that stuff. And if not MSC is 35 min from me.
Looks like you got the exhaust with 2 cats.
90917-06057 Gasket for photo
90105-10388 Bolt
90179-10133 Nut
Parts catalog for Toyota 4Runner
https://dz310nzuyimx0.cloudfront.ne...e3cf87cd/759dad5525c743ddff8d02285634e733.png
So that is the diagram for where that gasket goes, in the diagram it is in position 9 but the one I need is in position 11. Are they the same gasket?
Also, the bolt doesn't fit my vehicle when I check for fitment on McGeorge Toyota's website :doh:
Is that diagram from a Tacoma?
I'm not sure, it was the diagram that was shown when I submitted my vehicle spec to check if the part had correct fitment.
17451(no.1) is the part number that I need but multiple of the same part number will show on parts websites and I'm not sure which is the correct one.
this is a 2001 VIN I pulled off ebay
this site has a very easy to use interface, you should be able to pull the part numbers you need from here.
EXHAUST PIPE | 4RUNNER VZN185L-GKPGKA RZN18#,VZN18# | JT3HN86RX10353568 | Toyota | Genuine Parts Catalogs | PartSouq Auto Parts Around the World
there are 2 different parts for that one...and I can't remember the one I used.
one is $3 and the other is $5 so maybe just get both and your good? if your going to fix this youself? I would also get the bolts/nuts for that connection?
17451 is not the part number, it’s an item code or something. I am confident that the one you need is the part number I posted earlier but at this point I agree with sleepydad, it’s really cheap just buy both since you’re worried
I found this link in an older thread a few months ago. I can't remember what thread it was in or I'd go back and thank the guy for one of the best links I've ever seen. Never again have I had to ask for part numbers!
EDIT: I just realized that I could search the site for "Japan Parts EU" to find that thread. Lo and behold, IT WAS YOU! Hahaha. Thanks for the link!
I found this link Never again have I had to ask for part numbers!
"Japan Parts EU"!
Been using that site 4+ yr now, find "your" part number, assembly drawings good reference also, at times better than FSM.
Edit: If more people used link Part # threads would disappear, maybe !!
